5th gen e locker axle in 4th gen
WildcatHemi
Kingwood, Texas
i know the bolt pattern is different. if i found a rebel elocker axle with 3.92 gears, could it be fabbed to work in a 4th gen 3.92 outdoorsman? can the locker just be wired to a switch or relay? will that play tricks with the computer system?
hunterdan
SE PA
2019 classic
Not sure if the mounting points for the suspension are in the same spots, but if they are, I don't see why you wouldn't be able to just wire up a relay and switch to trigger the locker.
