5th Wheel Gooseneck/RV hitch 2020 RAM 2500
Festus
South Carolina
2020 Tradesman
6.7L diesel
Hi
I just bought a 2020 2500 4x4 short bed diesel. It has the 5th wheel/Gooseneck towing package OEM installed. I would like to not use a a sliding hitch because of taking in and out.
The Pullerite company has a 5th wheel/Gooseneck hitch that has 8 inches of foward or back mounting on the Goose ball.
Due to the cab and turning clearance the King pin has to be 4 inches behind of the Gooseneck mount.
Has anyone used the Pulle Rite 3900 in a 2500 short bed truck?
Festus
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Right in the website they say that hitch is designed for longbed trucks.
I think you need to first consider what trailer you're towing. Some are made for short bed trucks with no special hitch. Another thing to consider is a Resse Goosebox.
The #3900 Super 5th is designed for long bed trucks, but is usable with short bed trucks with the right truck/trailer combination for those who don't mind making a larger turning radius to avoid cab contact.
2003F350
6.7 CTD
I don't have much experience with the new puck systems, but if you're going to use the puck system you may have to go ahead and purchase a slider hitch. I think all the hitches built for the puck system put the king pin directly over the gooseneck ball.
That said, I have had several short-box pickup trucks, and when using the in-the-bed rails, have been able to pull several different fifth wheels without needing a slider hitch. Of course, those are probably not compatible with the puck system, so you're still kinda up a creek.
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
DSCN3356.JPG DSCN3364.JPG DSCN3364.JPG DSCN3398.JPG DSCN3402.JPG DSCN3394.JPG I have the PullRite Superlite #2600 with the SB and tow my 5th wheel a lot depend on the front cap of you 5th wheel.
Festus
Festus
South Carolina
2020 Tradesman
6.7L diesel
Gentlemen,
Thanks for the information on the RV hitches. I ended with the Pullrite 3900, which is the same as above except it is a RV style hitch no a total gooseneck, pulling my Grand Design 303RLS and it is OK up about 88 degrees of turn. It all good Thanks
Festus
ManBOOYA
