6.4 Hemi Throttle Body Porting
SixFOURhemiHD
Ghost Rider
Alabama
6.4L 392 Hemi
So I want to try doing my own throttle body porting. I run a machine shop and we have CNC so I have that covered. Can anyone tell me what works well when porting the TBs on our trucks? Just a straight over bore or a tapered bore, or maybe an hourglass to create a Venturi nozzle?
Thoughts?
McBroom
Denison Tx
Hemi 6.4L
Following you.
Straight over bore.
If it works out maybe I’ll send you mine and the intake too. Port both for some serious airflow... I’m gonna try getting a hotter spark more energy.
Blue Streak Pearl off-road
Ratket
Arizona-
Last time I ported anything it was with a hand dremel. On the plus side moes performance sells ported thottle body’s for our trucks.
SixFOURhemiHD
SixFOURhemiHD
Ghost Rider
Alabama
6.4L 392 Hemi
Anyone have a throttle body that is broken they’d send me to try it out? I’d like to test machining it before I do mine. I have some other ways to do this but this is the easiest.
What material is the throttle body made of? Aluminum? Is it cast or billet? There’s a thought, maybe I could design a billet throttle body that uses the OEM electronics and sensors.
McBroom
Denison Tx
Hemi 6.4L
No one makes a ported throttle body for the 6.4L
McBroom
Denison Tx
Hemi 6.4L
TXCOMT
What’s the stock diameter of our throttle body??
I’m liking the modern muscle site.
Thank you for the link.
Looks like 80mm; Modern Muscle has some great stuff (not that our Nick and Matt don't, of course)!
BTW, I just found this guy; he offers overbored and modded stock TBs and can even do yours if you can afford the downtime! I may just go this route!
https://www.thefastman.com/throttlebodiesHemi.php
TXCOMT
theviking
I have a ported TB from Moe's (which is made by MMX) and not knocking it but just make sure you keep things in perspective. Probably worth a few HP at certain RPM ranges but in a 7000+ lb otherwise stock truck your gains will be very minimal if any. If you want to spend good money somewhere this is not the place to start.
Obviously if you're able to port it yourself then that's another story. If memory serves me correctly it's just tapered to the stock 87mm blade on the inlet side.
