6.4 intake manifold removal info from manual?
RedRaiderHemi
Hemi, Cummins, and back to HEMI
gotta do the egr hose replacement. The manual links here are for a 2012 with the 5.7. I inferred from some youtube videos there is a certain sequence the bolts should be loosened/ tightened. Anyone able to scan a few pages or point me in the direction for info?
Post #9 has the torque sequence,just reverse it.
Daw14
South Florida
Arent the 5.7 and 6.4 identical in terms of dimensions, bolt patterns, etc? I would imagine the torque sequence and values are also the same
Yes , a 6.4 truck intake makes a fine upgrade too.
Bolt pattern is they same ,however a few things up top change .
R
RedRaiderHemi
well, from what I have seen, 5.7 you have to remove the alternator, and the 6.4 you dont. But IDK, about to find out!
R
RedRaiderHemi
thank you!
sublime2300
