6.4 whistle sound
DURASPANK
Greenville,SC
When I first crank my truck up cold. I just started hearing a whistle sound when I put it in gear and engine rpms drop from load. Goes away if I put it back in park or neutral or touch gas pedal and bring rpms up. I thought it was belt squeal to begin with but eliminated that and still hear it. Truck just turned 50000 miles any ideas on where else to look?
Burla
2010 Hemi Reg Cab 4x4
Vacuum leak, outside chance exhaust leak.
DURASPANK
DURASPANK
Greenville,SC
Would a vacuum leak go away once it warms up? Also just changed exhaust from muffler back and we checked as much as we could see. I couldn't see all the bolts on manifolds and it was already warmed up. Once I got to muffler shop. Guess I'll have to pull the wheel liners out so I can see all of the manifolds.
Burla
If it whistles when it isn't moving and the belts and pulleys are good, I can't see it be anything but the vacuum or exhaust system. Maybe upload a youtube of the sound.
U&A
2016 3500 SRW
6.4 HEMI
As said before
Mine only does it in winter months. I have directly related mine to the air intake or throttle body having cold dense air passing it.m. The intensity changes with the gas peddle.
My ranger did it with a CAI too.
Sent while firmly grasping my redline lubed RAM [emoji231]
