6.7 cummins losing coolant, with no heat.
shock
Bg ky
6.7 cummins
My 6.7 is losing coolant, with no visible leaks. Replace thermostat, still didn't help. Trucks runs between 188-200. Oil looks good, doesn't white smoke, pressurized the coolant system all was good, head gasket looks good. Any suggestions
mtnrider
Georgia
How much is it losing? Head gasket, EGR, are a few things that come to mind but I wouldn't think it would pass a pressure test (may only show when it gets hot)? If it's not leaking it being burned or going in the oil, those are pretty much your choices.
Are you tuned by chance? if so that greatly increase's the chance of the head gasket going.
No heat is probably air in the heater core or it's clogged. Did it just start out of the blue?
S
shock
Bg ky
6.7 cummins
Truck is deleted and tuned. I don't have an egr. I add about 20oz a week. Honestly didn't really check until now. Truck doesn't run hot, it shows no symptoms of a bad hg , but then again I am not a diesel mechanic. I did notice before it got cold heater worked great when it was 80 outside now its 30 and it blows lukewarm heat
S
shock
Bg ky
6.7 cummins
Oil looks good, not milky looking. Just had it serviced a month ago and all was good. Truck runs and performs like it should.
Hornet7
New Mexico
There is a good possibility that you have a pinhole leak in the head gasket. Get a block tester, about $35 on Amazon, to find out.
Fuel35 67
Hanford
Check the overflow tank as well, they’ve been known to crack.
06 Dodge
Forest Grove, Oregon/soon Osage Iowa
6.7L CTD
I would still pull an oil sample... I just pulled an oil sample on mine today after finding the coolant about 1/2-3/4 qt low with no visible leaks, I saw no sign of coolant in the oil. As I see it the cost of a Blackstone oil analyst at $35.00 is the one of the best way to know 100% if I have coolant or fuel in the oil and it will give me a heads up if there is any internal wear problems...
oe542bob
Hemi eTorque 5.7
I went through this past summer. Can’t address the lukewarm heat issue, but in my case, I noticed my oil level had crept up. I do my own oil changes, so I knew it wasn’t overfilled.
Oil looked fine, a sample was sent to Blackstone, and it confirmed coolant in the oil.
In my case, the head gasket was replaced as well as the EGR cooler. ( Truck had around 119,000 miles and is totally stock ) It’s been perfect since late August when the work was complete.
S
shock
Bg ky
6.7 cummins
Problem solved. Heater core was so stopped. My diesel mechanic had to flush it out 3 times before coolant would flow like it should. Heat works great now
Corey_lax
British Columbia
I had a leak somewhere for years, same symptoms as you. I flushed out the heater core and got it flowing again. I finally pulled the plastic piece off the top of the radiator and found a small leak at the top of the radiator. Not a big enough leak to notice anything on the ground, but enough to let air into the system obviously. New radiator installed over the weekend and I now have 140 degrees coming out the vents!
Arturo Rojas
