ggrimm01
- Dec 30, 2018
- 26
- 19
- Location
- Louisburg Kansas
- 2018 Ram 2500
- 6.4
Hello all,
My truck has been throwing the P241A code. I have been investigating the 01 and 02 sensors through AlphaOBD. The voltage runs between 1v and 13.5v and seems to be working. However, on 2 occasions, I saw spikes to above 20,000 on each of the sensors. However, these did not throw the P241A, and the truck has no-fault after several test drives. I have performed the zero fueling event numerous times and this has seemed to clean up the DTC faults. I see there is a TSB for this and the remedy is to clean the sensors, change the sensors, or change all including the module. My question pertain to see if anyone has had any luck with this Fix?
Sent from my XP8800 using Tapatalk
