Happy Thanksgiving
I have a 2018 2500 6.4 gas with an 66rfe intermittent transmission issue. 95k on the transmission. Truck shifts awesome around town, getting on the highway when it downshifts occasionally there is a hard shift then the truck gets stuck in maybe 4th gear. I believe it is 4th gear but not positive. Truck only goes from 1st to 4 gear afterwards until the truck is shut off. Once the truck is shut off and restarted it is no longer in limp mode and runs great. It could run great for 1k miles before it happens again or it may happen right away.
It is intermittent. No codes and the transmission fluid has about 25k on full synthetic fluid. I have been told it's anywhere from 5k-8k transmission job. Maybe the transmission is on its way out. Any ideas on possible other solutions? maybe solenoid or valve body?
