8.4 with Nav
bhonshell37
Washington
2017 Ram 1500 Sport. I have a Note 9 that previously was connected to the 8.4. I could make and receive calls and play music from my Note 9. Today driving from work, a call comes in. I notice the call is only through the phone. I get home and try to connect the phone and only music is functioning. I turned off my bluetooth and reconnected to no avail with only music. Before dinner I deleted the phone from the 8.4 and now am unable to reconnect. Uconnect is visible on my Note 9. I have researched and tried the steps I found. Any help is appreciated
Michael
In an undisclosed bunker
When you deleted your phone from the 8.4 did you delete the 8.4 from the phone also? Try deleting from both and rebooting the phone before trying to reconnect. You might also try disconnecting the trucks battery to see if that will help reset the 8.4.
I personally think the oem head units are low quality. I had trouble with mine. I even bugged the stealership until they replaced it. I still had trouble. I replaced it with an aftermarket one and no problems since.
B
bhonshell37
Washington
Awwww. Delete the Uconnect from my phone. I will try this. Tomorrow morning I will try to reconnect my phone to the 8.4. Thank you for the information
8732cuts
US
Don't disconnect battery just pull fuse located near firewall where steering is. I have note 9 also
B
bhonshell37
Washington
In the time with your Note 9 and Ram, have you experienced my situation?
B
bhonshell37
Washington
I deleted Uconnect from my phone. Yesterday morning I tried to connect the phone again. Still unable to use the phone. My cell provider is Xfinity. Going visit the local store to see if someone there can help
B
bhonshell37
Washington
I had an appointment set with Xfinity. I get in my truck and start the engine. Wait for my phone to connect. Uconnect asked for permission to connect with Bluetooth and I granted permission. Today my phone received a security update. Could be the reason I can make calls through my head unit
