This is from ALLPAR's website but it appears there's three clutches with two brakes and two shift elements open per gear. The stepped gears stump me as well. I always thought the point of TC lockup was to cut the slip out of the TC and help cooling? On a normal accel what's the purpose of the TC lockup in any given gear? It appears that this trans can lockup in 1-8 if the conditions permitted. Thanks again for letting me bounce my OCD worries off ya! Lol
As Allpar predicted, the transmission uses four planetary gearsets and five gear shift elements (two brakes, three clutches); there are two opened shift elements per gear, minimizing drag losses. Efficiency is higher than the 6HP transmission in first gear, lower in third through fifth, and higher in sixth (identical in second). Only two shift elements are open in each gear, cutting parasitic losses, and extreme transmission shifts, such as eight-to-second kickdown, are possible.
Original is at*845RE / 8R70: ZF 8-Speed Automatic Transmission for Chrysler cars*
Follow us:*@allparcom on Twitter*|*allparcom on Facebook
