86 D250 Hemi Ramp truck build
Loggato
Kansas
Hello, I've always low-key wanted a ramp truck. Mainly because I'm tired of either trying to borrow a capable car trailer and/or dealing with the incompetency of said trailer, such as a winch battery that's always dead, a flat tire, worn-out tires from missaligned axles and then you just have the general things like dicking with ramps, fenders always in the way and then here in Kansas a trailer typically needs it's own tag and registration.
Well, if you're like me, for a project to happen things must fall into place. A buddy's wife rolled his 03 ram and another buddy took the engine and trans out of an 86 that he needed for another project. Let the fun begin! I bought the 86 for $300. It came with everything BUT engine and trans. and I bought the rolled 03 for $500 and let my buddy have it back for scrap when I finished.
For the new trans, I was able to find a NP435 and NP208 (I think). It came with a 360 clutch and flywheel.
now for the important part: if you want to put a Gen3 Hemi in front of a NP435 just use a 05/6 flywheel from a 2500 (manual trans), a pressure plate from a 86 (or similar) 360 with 11" clutch and also the clutch disk from the 86 (matches splines on NP435). For the pilot bearing just use one from any small block that had a 3/4" input shaft - Mine was a National FC-69907. The only new parts I had to get were the flywheel, pilot and throwout bearings and the clutch fork. You'll also want to make sure you get longer crank bolts. they are M10 x 1.0, I had some laying around from a Mercedes engine. Lastly - cut 1/4" off the input shaft.
So I'm sure you're tired of reading, but just a couple more things. For motor mounts to a D250, I just made some 1/4" adapters that bolt to the stock 03 motor mount bolt and then bolt to the 2 holes on the 86 frame. fairly simple but forgot to get any good pictures. As of right now, I'm not sure how exhaust will work around the clutch Z-bar and I believe I need an older style starter but not sure yet and lastly you'll need a oil-filter relocation kit. Mine is on the way and I'll cover that soon.
Thanks for reading and here are some pics:
Loggato
Loggato
Kansas
For wiring, I just snagged everything I could from the 03 and will be finding a spot for it on the 86. I do not believe the 03 had any security which should make things easier.
a few more pics.
Loggato
Loggato
Kansas
ECU's mounted to RH inner fender. 03 fuse panel and main harness mounted and routed into LH fender and radiator nearly done being mounted
Fryekenn
