87 or 89
Aries75
Maryland
Hemi 5.7L V8
I have been filling up with 89oct since the manual suggest it. But Can you run 87 in the HEMI and it will still run good?
RAM_Designs
Rockwall, TX
6.4L Hemi
It recommends 89, I use 89. It says that 87 is acceptable...but obviously they recommended 89 for a reason.
Kotta390
It will be fine. The PCM will adjust accordingly and in cooler weather months I can almost guarantee you won't feel/see a difference between the two fuels.
xrsman
Ontario
3.0 Ecodiesel
This ^
Sent from my SM-G920W8 using Tapatalk
jon0m0berry
ive ran both and my truck seems to drive better with 89 but does just fine with 87 but I have also seen like a 1.5-2mpg drop running 87. most of what ive heard/experienced running 89 youll spend more at the pump but see it less often, and that the cost between both is the same. ide say if it costs the same might aswell just go with the 89
loveracing1988
Clarkston, MI
Only a handful of times in the year I have my 1500 did i notice a difference between 89 and 87. I noticed zero fuel economy gain going to 89 as well. I didn't start noticing the difference between the two until I got my vararam, stock I never could tell.
Bullitt279
South Carolina
I ran 87 for about 2 years and I always thought it ran fine. I recently switched to 89 and maybe it's in my head but sure seems running nicer.
Aries75
Aries75
Maryland
Hemi 5.7L V8
its a 20 cents difference where I'm at. only reason i ask is I know my wife forgets when she go gets gas and pumps 87.
jon0m0berry
yeah pumping 87 wont hurt anything, my wife tends to use 87 at times as well
ExpressRules
Southern New Jersey
2019 Big Horn Crew Cab
I've used 87 from the day a bought the truck in Feb of 2014. There have been several long distance trips made over the time I had the truck that I had to refill with 89 cause 87 was not available. I noticed no performance difference between the two.
Firebird
2019 Ram 2500
My Hemi does not like 87 octane
GP4L
Chicagoland
OP, you'll be fine. The ECU will pull a little timing out to compensate for the lower octane. You'll maybe notice a drop in performance, including fuel economy. Modern vehicles will always safely run on lower-than-"recommended" octane fuels within reason. Just don't expect the engine to safely perform in high-load situations, like towing or hauling heavy stuff, for example.
Jerry1984
Meridian, Idaho
I run 87 anytime I don't plan on towing. Haven't noticed any negative affects. I tried 89 a few tanks when the truck was new and didn't notice a difference.
lagerstout
Somerdale, NJ
HEMI 5.7
Does the use of 87 to save money actually 'cause you to spend more money through the loss of MPG 'causing you to fill-up more often? I've always used 89.
RodRam
Ga.
i run 89, it runs great i see no reason to drop to 87, my Chevy would not run on 87 without pinging even though the computer should adjust it didnt, it pinged less on 89 but ran great on prem. so there is a difference
Jerry1984
Meridian, Idaho
picture.php
jknappen
Kentucky
Ran 87 since day 1 no issues what so ever. I throw some injector cleaner stuff in it here and there. No issues and 1-2 mpg isnt ****. You bought a truck if you were worried about gas mileage you should have bought a prius..... Just sayn
Doug70767
