94 1500 318
S
swillest
I could go to the scrap yard and get em for 10$ per.. but I dont wan't a bad injector from there lol
Merc225hp
NA
truck
gas
Don't bother getting injectors yet.
Just read through the thread again, time for a comp test and you need to fix the plenum gasket.
S
swillest
I haven't seen hardly any oil in the intank manifold when I had TB off. I wouldnt guess the plenum is blown.
Merc225hp
NA
truck
gas
You can't go by that wives tail, you just have to expect it to be bad until you replace it. Its not hard to do nor is it expensive.
S
swillest
Sure thing, but first I'd like to be able to drive her to work without failing... so injectors are first imo.
S
swillest
Today, the injectors go in...
Wish me to luck! I want all 8 cylinders to work...not 6 :D
Merc225hp
NA
truck
gas
Good luck then, hope it works for you. :)
S
swillest
Alright.
I am thinking I should take some videos of what's going on, because I am so lost on this truck.
New:
IAC
MAF
Ign Coil
Plugs
Spark Wires
Cap + Rotor
Fuel Pump/filter
Fuel Injectors (2)
I installed the new injectors today- she runs better for some reason, but worse at the same time. (I think its easier to hear its faults now)
Still, when I pull the fuel injector connectors on cylinders 5,6,7- there is no change in idle speed. So I pulled the plugs and since they were new, they will show something...THEY WERE WET! So I know this motor is getting fuel, but the plugs look like they are still brand spanking new..no carbon which leads me to think no spark when running.
Anyone?
S
swillest
Would a bad Crankshaft Positioning Sensor cause a few cylinders not to fire?
S
swillest
EGR valve on the rear of the motor??
thoughts anyone?
Merc225hp
NA
truck
gas
CKPS can it cause a missfire yes. To be replaced with a Mopar part only.
S
swillest
I am going to pick up a CKPS and swap that out... Still thinking its the EGR on the back of the motor.
Merc225hp
NA
truck
gas
Remember to reset the pcm with all these new parts.
S
swillest
Codes Stored: 33 and 21.
AC Clutch Relay...don't care.
And 2 is O2 Sensor, which was new from bosch. But I doubt an o2 sensor would cause certain cylinders not to fire..
Also changed the oil after changing the oil 311 miles ago...black as dirt. No discoloration though, 5 qts came out, looked fine..no milkiness.
edit/update: Unplugged the connector to the CKPS, tranny oil came out of the electrical connector..I'm thinking I am getting warmer...
S
swillest
Well, I think I am done throwing money into this pit...
I am going to pickup a 95 ram 1500 from a buddy and use my 94 as a donor truck for parts. I will probably take the heads off and re-man the heads so when the other 318 blows, I'll be ready.
95 1500 shortbed, 318, 2wd with 220k
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Transmission fluid coming out of the CKPS connector? Something is definitely off there. lol
S
swillest
Yeah...more on that this weekend.
Sent my truck (as a last resort) to my buddy's shop. Distributor cap was bad, but not on the posts or cracked or anything...this one got me. 3 "prongs" if you will on the INSIDE of the cap were TWISTED and melted the plastic enough to cause it arc to each other.
Now she purrrssss......:word::3681700201_eef6d1e2
Merc225hp
NA
truck
gas
Not weird at all seen this lots. At least its running.
ADudeOnSkis
Truckee, CA
318/5.2 Magnum
Tranny juice out of an electrical connector? Wow, cant wait to hear that story.
Glad its purrrrring, every thing seem to be normal now?
KAKA
