Damian
Dothan
1995 318 idles semi ok cold but spits an sputters when warm. Won't get past 15mph after a 2 min drive. New plugs, wires, map, tps, aits, crank position sensor, air filter, o2. No vacuum leaks that I know of. Any advice would help.
ad80721
Sarnia, ON
I say it's time to splurge. Go grab your wife and kids and go truck shopping. Make it a family fun adventure. I'd say go for a 4th gen ram. They look nice
thestuntboy
Supporting Member Marine Corps Air Force
CT
1999 2500/2001 2500/2018 3500
8.0/5.9 gas/6.4
Just to throw it out there, when you changed your TPS,IAC did you thoroughly clean out the throttle body?
Grab,borrow,steal a handheld propane torch and without lighting it run the propane around the intake/vacumn connections, if your hear improvement bingo air leak.
It sounded like your exhaust was loud but if you havent already disconnect in front of the Cat and see if improved. Good luck!!
rockyj69
