A/C performance
Devin1349
Hi guys so i was wondering am I the only one who's ac blows cold only when going highway speeds (65+) but wont blow cold in city, i noticed this within the past week ive driven just in city and it would get a little cool but not as cold as it does when im going 65+. is there something wrong with my Ram?
bhonshell37
Washington
I to am having an a/c issue. I have read about the blending doors not closing fully. Dirty radiator ect. Pinching one of the hoses to see if the problem is solved. My ac blows 59 degrees right at the middle vents on high recirculate. What is the temperature at on high?
Sent from my SM-T550 using Tapatalk
Devin1349
Devin1349
I dont know any temps or anything in my Ram I have the ST trim so its barebone as they come (I'll be upgrading to laramie longhorn someday) but as for right now i can say i definetly need to clean under the hood but I dont know if that will help my a/c get colder when i get the chance im going to double check the freon lines for leaks.
electricyeti
South Texas
Not being a smart ass but it's the thing that looks like a radiator in front of your radiator
Sent from my XT1585 using Tapatalk
Devin1349
Devin1349
ok well i was looking around there and i do have some bugs and dirt my big thing is im afraid of cleaning under the hood because I dont want to damage anything otherwise id just go to the self service car wash and use the "under the hood" mode
bhonshell37
Washington
You will fine. Use air or a water hose to blow the debris from the opposite side. Or use a bristle brush to remove all the debris
electricyeti
South Texas
Just don't fold the fins and you should be fine. Should see a big difference. If that doesn't work find someone with a/c guages with MV hookup and check the charge.
Devin1349
Devin1349
@electricyeti, I hope i dont need to recharge i just had the lines fixed last year and had it charged if it does that tells me I might have to have more work done to it... or trade it in
electricyeti
South Texas
That's the next thing I was going to say. They are very overlooked.
WiSH2oo0
MN
2017 1500 Express 4wd RCSB
My AC sucks in my 17 RCSB . My G6 will freeze you out but this truck isn't the best. When it's on recirculation and the outside temp is 81 , I shouldn't need my AC on full blast to cool my cab down.
Devin1349
Devin1349
Well im wondering if a leak would affect my ac depending on how fast im going??? like I said it only get cold if im going 65+mph and then it will stay cold until I turn off my truck and let it sit for a little while
electricyeti
South Texas
I would still focus on the airflow first. Then maybe check to see if it's the 65+ or if it's because of the sustained higher rpms. I can only assume whoever did your repair got everything tight and did a good evacuation of your system before recharging it .
If there is an electric cooling fan for the AC system, make sure it runs when the system is running.
joshhhh
