A couple stereo questions
Hockeydad55
Santa Clarita,California
So I'm going to keep the 5.0 uconnect for a while and just change out the speakers for now and amp and sub later.
1st question do I stay with 4 ohms or can I do 2 or 3 as long as all speakers are the same ohms
2nd I like the bass my system puts out right now to keep that or better would I stay with 6x9's 2 way or 6.5 2 ways in the doors witch one would have more bass.
3rd what power range for the speaker could I use with the 5.0 do I have to stay under a specific range.
Thanks for the help
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
If you want more midbass up front, IMHO stick with 6x9's, and 4 ohm is fine.
OrionR5
Toronto, Canada
2019 Ram 1500 Sport
Graygoose what 6x9 will fit the front doors. I posed that question and was told that most guys are running 6.5's up front because a 6x9 will not fit.
I installed Kicker 6x9 in the rear doors and thought it would be great if those will fit the front doors. I went ahead and ordered a pair of Kicker 6.5's from Crutchfield.
Etroze86
Grand Forks ND
6x9's fit don't let anyone tell you different its just how much work are you willing to do to make them fit.
Graygoose
Oklahoma
Convert, for now.
small
Yup, some have huge baskets and magnets, some dont.
So its a yes and no kinda :)
MoreOvalteenPlz
Stillwater, OK
1- stick to 4 ohm
2- 6x9's will provide more low end
3- power range should only matter if you amp them
Ryan1126
San Diego, CA
5.7l hemi
with the stock headunit power, stick to 6X9's if you plan to amp them later i would do 6.5 components, with the right set you would be very surprised what type of midbass you can achieve.
