Alignment Questions
Yardbird
Western NC
Did they reset the steering angle sensor with a scan tool? If not, that could be your pull also.
Hook up tool, go to program module, turn wheel lock to lock each way, then back to the exact place the wheel is at when the truck is going straight down the road, then reset the module.
You can set the module with the steering wheel centered, but if the wheel is normally off center when going down the road, the wheel alignment will need to be centered up, or the module programmed at the direction the steering wheel is pointing when going straight ahead.
The steering module is supposed to be reprogrammed at every wheel alignment.
joesstripclub
Kansas City, MO
2021 2500 PW
I can't say I've heard of this before but its good to know in case its encountered down the road. Can you reset the sensor with AlfaOBD or is this a higher end scan tool operation?
Yardbird
Western NC
That I don't know. The guy that did my alignment did it with a SnapOn reader.
rockyj69
