A penny for your thoughts...on a 2 inch front drop
ChiChi
Pennsylvania
5.7 hemi/6.7 Cummins/6.7 cummins
So heres the not so short and sweet on my current situation.
I just bought a 3rd RAM, this is my first gas motor truck and it is my daily.
The truck is a 14 RCSB with the 5.7L motor, 6 speed auto with 2wd drivetrain. I bought the MOPAR lifetime extended warranty so I do not intend on voiding that.
With that being said I am able to raise or lower the the truck 2 inches and not void the warranty.
I already purchased a Ground Force rear 2 inch drop and I'm just waiting for it to show up. I have been tossing around the idea of buy a set of Crown Suspension front 1 or 2 inch drop springs.
I bought this truck to be a turn key no issue just drive it sometimes like I stole it truck. I am wondering what issues if any I will encounter if I also drop the front end up to 2 inches?
Essentially I will have either a 0/2 drop, a 1/2 drop, or a 2/2 drop. Any input guys???
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I did a Belltech 2/4, just reuse your factory shocks, don't use the shocks. Just order the front, or the Crown, but I don't have any insight on them.
I ran a belltech 2/4 drop for 5,000 miles with oem shocks and no issues.. I have the front 2 inch drop springs if you want to get a good deal on some.
ChiChi
ChiChi
Pennsylvania
How much for the shocks??
ChiChi
ChiChi
Pennsylvania
I meant how much for the front springs?
I only have the front springs and full rear kit, I bought the belltech kit without the shocks. ac0e426a0f24540e904939571984b281.jpg3b1f2115d1325858dfc4b94829afeb0d.jpg
ChiChi
ChiChi
Pennsylvania
Are you interested in selling just the front shocks?
ChiChi
ChiChi
Pennsylvania
I meant to say just the front springs
If you want a 2" front drop that rides like stock and wheel aligns to factory specs,look at Mcgauphies drop spindles.They're actually easier to install then a set of front springs and re-use your stock front shocks
ChiChi
ChiChi
Pennsylvania
I’m alright sacrificing ride quality, I just don’t want to effect reliability or....cause issues(death wobble, poor alignment, blown ball joints, etc)
You think springs will do that?
It's your call,but a spring drop makes the tie rods run uphill which can lead to bump steer. A lot of guys will say it's not an issue,but after doing a spring drop on my old 13,i'll never do another unless I also do a tie rod flip. You might also have to cut the tie rod ends off slightly to get it to come into alignment specs with a spring drop,but that seems to be a hit or miss situation,some trucks come into spec with-out tie rod trimming,but then the next truck needs them trimmed
Motorious
kentucky
2017 rc/sb
Found out from McGaughys that those spindles are fabricated to avoid the caliper and brake lines so they are wider than stock and move each front wheel 3/8" out. They said the 3/4" total increase in width is noticeable when done.
DwnDak
Ontario, Canada
With a 2" rear drop your going to be sitting level I assume?? I don't know what the 2wd OE ride height is since they're a rare truck in this country.
If your only going 2" out back, and that ends up making it level. I'd leave the front. Personally I'd probably go with a 2/3 if I was you, but I've got a 2/4 and its not low enough.
Remember warranty is only effected by parts that can be shown to be the direct cause of the failure. So if you blow a motor... lowering the truck won't be an issue. If you blow a trans or rear end.. They may try to fight you on lowering, it all depends.
Two Dog
Ontario, Canada
2014 RAM RCSB Express
I have a Ground Force 2" rear levelling kit and was thinking about a Crown Suspension 1" front spring drop for a 1/2 overall drop (on a 2014 5.7 regular cab short box Express). Would the 1" spring drop really be that detrimental to the trucks handling and alignment? I am about to order the 1" drop springs, so any insight would be helpful. Like Chi Chi, I don't want any adverse handling.
Thank you.
Thank you.
A 1" drop will not change your geometry that much, and the small amount of camber you will gain can be adjusted out with the stock camber adjustment. Im sure others will have other issues and insight to add, just my 2¢
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
Thank you.
Crown suspension 1 • 2 drop...
Two Dog
Ontario, Canada
Looks great Booms, just what I'm after but with 20" rims. Although I'd kill for a nice set of R/T rims. Did the front end align OK without any funky handling? I'm happy with the way my truck handles now and do not want to deal with any quirky handling, uneven tire wear or any other compromises.
Thanks.
Booms
The OG
Ocala
2015 Express
It aligned real easy. Truck rides perfect. It tightened it up a whole lot.
