Deaconsfan
So after replacing the rear abs sensor and both speed sensors, the trouble codes remain. I finally took it to the shop where they confirmed my suspicion that the abs module was bad.
I’ve read that this is pretty much a dealer specific item, and that it needs to be flashed to my vehicle?
However, I just stumbled across ( think it was a charger forum) where someone posted success with a used module without being reflashed as long as the part number was the same as the original. Any truth to this?
