ABS Sensors
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Ok I know I had a thread a while back about the ABS and brake lights being on on the dash. Ok I just wanted to update everyone. So here it goes.
If you have the ABS module that sits horizontal on top of the pump you have the AWABS (All Wheel ABS). If you get the ABS and brake light lit on the dash it could be a number of things. But here is a list of components to check.
Rear abs sensor on the rear axel
Front ABS sensors on each front hub. This is for 2wd and 4wd
The ABS fuse
Now for a question. Where can I find the front sensors? Mine is dead. Been looking online but having a hard time. Gonna check with the vendors here and see if I can find it.
Sent from my DROID RAZR using Tapatalk
