AC cut out, then on, now out longer?
Frankwhoa
LA
Hello everyone,
I was idling yesterday and the AC went warm. I cycled it off then back on and it starting blowing cold again.
Same thing today except this time it is warm no matter what I do. I've cycled it, turned off the truck, etc. It doesn't look like the compressor clutch is spinning.
Any ideas, maybe a relay, fuse, etc?
Update: blowing cold again...
Update 2: blew cold for about an hour, now hot again
41k miles on a 2016 Certified Pre-Owned
bigdodge
If the compressor isn't cycling then u need to see what the pressures are running. It might be too low. If it is then it's leaking somewhere
Sent from my Pixel 3 XL using Tapatalk
Frankwhoa
Frankwhoa
LA
Got it fixed. Bad connection at the compressor wiring connector.
Cut waterproof connector out and spliced wires together with waterproof connectors.
southalum
