AC Temp
tippycc
5.9 Diesel
My AC blows out at 42 to 48 degrees.
Should the temperature be in the 30s at max?
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
this should list what you're looking for. Ambient temp and airflow past the AC condenser is important.
T
tippycc
5.9 Diesel
Thanks but I have a 2001.
chopperman1
Peoples Republic of Massachusetts
2018 Rebel
5.7L HEMI
Doesn't matter what year you have. A good rule of thumb is a 20-30deg temp difference across the evaporator is what you should have. Example, 80 deg inlet air should give you between 50 and 60 output air.
T
tippycc
5.9 Diesel
I have a new compressor and a new evaporator the outside temperature was in the 55. My output air was fluctuating 40 to 48 on the maximum setting.
