Accessing Fuse for Integrated trailer brake fuse and voltage output.
Fisherman95338
california
5.7 v8 gas
2019 RAM How do I access the fuse panel for the Integrated Trailer Brake? Its called the Internal Power Distribution Center, I can see it, but can't see how to change the ITBM fuse if it blows on a trip.
First time towing horse trailer with RAM 1500 2019, I jack knifed and crushed the umbilical, blew 3 fuses fortunately just lights. (OUCH $5 per fuse at store in the mountains. After rewiring umbilical and checking output from truck connector Trailer brake controller puts out 5.87 Volts with brake pressed hard. Seems OK. But if I do this again and blow the ITBM fuse How do I change the fuses to ITBM, it's in the cab drivers side, and I can't see the fuses. Tried removing the trim, but that's not getting me there. If I have to do this while on the road what tools do I need 12mm deep socket, and ????.
Sorry for duplicate posting, I saw this same question a few weeks ago, but can't find it again.....
There are separate fuses for the ITBM and the +12V for the brake output. Look for the brake fuse in the under the hood fuse box. For the fuse box inside the truck, you need to pull the lower dash panel.
