Accidentally put Transfer Case oil in Rear Diff
sirdumpsalot
Anchorage
Changing my rear diff fluid today and I pulled a real genius move and started putting transfer case oil in instead of the rear diff oil. I caught my mistake when I had about 1 quart in there (the red gave it away), immediately drained it, flushed some of the correct stuff through until I couldn't see any red. Filled it up correctly with limited slip additive, drove it a few miles, drained and filled it correctly again. My question is:
Should I get it rebuilt or anything?
Flush it again?
Stop worrying?
In my defense, the bottles were shaped the same way.......
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
If you did a drain and fill/flush you should be totally fine.
What oils did you mix up? As in brands and weights
S
sirdumpsalot
Anchorage
Put about 1 quart of MOPAR BW44-44 in, which I'm having trouble figuring out what viscosity that roughly translates to, but it's red and seemed much lighter.
Flushed and filled it with MOPAR 75w-140 with 5 oz of limited slip additive.
BW44-44: 68089195AA
75w140: 68218657AB
I doubt you would have done any damage to the differential even if you ran the transfer case lube for several hundred/thousand miles.
Only thing that took damage was the wallet having to buy extra fluid for both.
S
sirdumpsalot
Anchorage
Cool beans, thanks guys. You're right, the wasted oil hurts the old wallet. I got a bunch of OEM stuff for a steal from summit racing awhile ago but that deal is long gone...
Socalramfan
Huntington Beach
2011 Big Horn
For insurance, if it were me…… as mentioned I’d flush, plus do another oil change after driving it for maybe 100 miles, then drain it again.
Maybe over kill, but I wouldn’t forget that mistake again :waytogo:
Brent 1955
Kansas
Flush it again?
Stop worrying?
Drain it use brake clean on the inside of the differential blow dry it all out till dry and replace with gear oil and (limited slip oil if you have a limited slip). And one quart of Lucas oil treatment. Doing mine this way haveover400000 miles on my differentials now. And over 600,000 mileson the truck.
