Accidently Poured 3/4 Gallone of Wiper Fluid Into Radiator Reserviorv
malatu
DE
3.6 L Pentastar
Jeez... Was in a rush and stupidly poured 3/4 of a gallon of rain x wiper fluid into the radiator reserve/expansion tank. I'm out of town and getting ready to make a 350 mile trip home. How concerned should I be.
I am going to try to remove as much as i can but not sure the best way to do that. Any suggestions?
Sandbox
Warrenton, VA
SST SO
I'd drain it before I started on my trip. I wouldn't want to find during the 350 mile trip that I should have. As long as it's just in the reservoir, it should be pretty easy to do.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Have you run the truck at all? Drain the reservoir and put coolant back, if you did run it and the truck got up to temp then "I" would recommend flushing the cooling system.
M
malatu
DE
3.6 L Pentastar
No, haven't started trip yet. On way to store to get some tubing to siphon out.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Should be a couple 10mm bolts holding it down, if you pull those you'll be able to pull it out and dump everything out and give it a good rinse. If you had run it and got it to temp it quite possibly would have siphoned some from the reservoir into the cooling system. You should be good as long as you get it out.
ExpressRules
Southern New Jersey
2019 Big Horn Crew Cab
Since you haven't run the truck ^^^^^^ this.
m00nraker
2013 RAM 1500 Express
I did the same thing before. Drove it for awhile before I realized what I had done when I went to use the washer fluid and nothing came out! Hey I just filled that! Yeah, oops.
I didnt do anything. Drove it and never had a problem.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Don't worry, we all get in a hurry and we all make mistakes. They put those tanks right next to each other so it's bound to happen to someone, makes wonder if they purposely designed it that way knowing it would happen and cause damage and make them money on repairs.
SHOOT2KILL
2015...2500H.D.
I wonder how many times this has happened to people at oil change places, that have never been told by the tech that it happened...
Broyd
Rossland BC Canada
IF you haven't run the truck since you dumped RainX into your overflow tank, then you can remove the tank and thoroughly flush it out. (Are you using a different vehicle to go to the store for tubing?)
Be aware that the coolant used in your 2016 is MOPAR OAT. It is PURPLE in a clear container. It is not your everyday off the shelf coolant. It is expensive. If you mix anything else with what is already in your truck, you could be setting yourself up for some very expensive repairs. There are a lot of threads about this. Here is one of them!
ATTENTION: Know Your Jeep JK Wrangler Coolants and Save Your Engine!
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
It's an expansion tank , reservoir , hence zero pressure , plastic cap
You could drive the truck home the whole 350 miles and the reservoir probably wouldn't lose or a gain a drop , and clean it out at home
Unless you have a coolant leak or major issue with your coolant system
Now if you removed the pressure system side metal radiator cap and poured it in there , I would be concerned
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
And the reason it took 3/4 gallon , its designed for expansion and contraction
You probably topped it off then realized what you did
You and 10 million other people at those 10 minute lube jobs
The full line for that reservoir is probably only at about 50% or less
avantiguy
Bay City, Mi
hemi
Window antifreeze is essentially water with alcohol added, your coolant is water with antifreeze added. If you dumped the coolant tank before you started the engine then there would be little if any window antifreeze in it.
The problem with mixing various engine antifreeze's is the changing formulations which shouldn't be an issue if you refill the empty tank with the recommended stuff.
Any small amount of window stuff would be the same as adding a few drops to an ounce of alcohol to your antifreeze which I would think would have no effect.
Everything is soluble in everything and the change in any property in the coolant system with such little amounts is hard to imagine.
IIWM and I had emptied the tank prior to driving the truck, I wouldn't be concerned.
JMHO
Burla
2010 Hemi Reg Cab 4x4
Nobody siphons anymore, easy peasy done in 5.
chopperman1
2018 Rebel
5.7L HEMI
Turkey Baster, suck it all out, rinse with some water, suck that out, fill it to the correct level with fresh 50/50 (use the right stuff), call it a day....
M
malatu
DE
3.6 L Pentastar
Back home safe and sound! Used different vehicle and picked up a siphon at the auto part store. Siphoned out the rain x, added a gallon of water to the coolant reservoir and siphoned it out. On the way out of town I stopped at the local ram dealer and purchased the correct coolant and refilled the coolant reservoir.
Yes, "Easy Peasy!"
Thanks for all all the comments and suggestions!
Cheers!
malatu
shibby927
The Great State of Iowa
Did this in my truck a month ago, in a hurry to leave for Christmas, threw in a jug of fluid and realized my stupidity immediately thereafter. I siphoned mine with a chunk of heater hose because I didn't have the time to be taking things apart. I managed to get most of, if not all of it out that way. Been running perfectly fine since though I'll probably get it flushed sooner rather than later just to be careful.
Everyone makes mistakes. Ours wasn't paying enough attention, lol.
xrsman
Ontario
3.0 Ecodiesel
Glad you got it fixed up. In high-school my buddy accidently put washer fluid into his brake fluid reservoir. Had I not said anything he wouldn't have known what he did. He had to get that all pumped out, I remember his dad not being too happy, as it was his truck! Haha
Sent from my SM-G930W8 using Tapatalk
Johnnguyen6596
