Adding Air Suspension
Glowrdr
Minneapolis, MN
Bought this truck to use for towing (upgraded from a 1500 for this reason, but have nothing to tow as of yet) and have a couple questions.
Is it worth having the OEM air? Not sure if this is something that can be added easily or not. Don't know the differences of having an OEM system vs aftermarket besides cost.
I like the idea of being able to lower the rear for loading, unhooking, etc - is this something that's pretty common? Or is that one of the benefits of having it integrated with the truck via OEM?
The rear sits up so dang high, and I'm not getting any younger. I'm either going to need the rear to drop down some, or I'll have to look into a step of some sort. But since I'll be towing a 5th wheel, having the truck level is probably my best long term solution.
An aftermarket systems can raise and lower the rear of the truck but it won't be integrated like the OEM. Both aftermarket and the OEM will cost a bunch of $$ to be installed after the fact.
Most of the time people will add airbags to the rear just to level out the truck with a big load but it won't lower the truck below the ride height now. This way is safer as if something happens to your air system, your not stuck on the side of the road.
Have you looked into an Amp Bed Step?
http://www.amp-research.com
G
Glowrdr
Minneapolis, MN
I have not, but will check that out now. I've only really looked at the "hitch steps" - but that doesn't do me much good either since I'd have to lift my legs to waist high to step on it!
Good call on the suspension vs air bags setup. I believe I'm more interested in the air bags (just using the wrong terminology) - but I was not aware that you couldn't lower it at all, just leveling. Makes sense though. I guess bags and a step it is!
Totesmygoats
you can lower it, 2", hes talking about the cheap aftermarket manual fill bags, which allow you to only raise the back when hauling, which is actually pretty useful.
Raadz
