Adding fuel additive
Jimmie Hensley
Asheville
2018 Ram 2500
Hi every one! Probably a dumb question but today I tried to add diesel kleen to a tank of fuel and when I poured it down the spout it ran out the wheel well and is sitting in the fill tube. Is there a secret to getting this stuff in the tank? I’m assuming there is an extra flap in there I can’t see
Thanks!
mtnrider
Georgia
Need a long funnel, there is a second door flap in there. Should be one under your passenger seat but I wouldn't put it back in the truck after using it, it's for emergencies where you need to fill from a can.
J
Jimmie Hensley
Asheville
2018 Ram 2500
Okay thank you guess I’ll be looking for one.. any suggestions? not being sure what was down in there I didn’t want to break anything
Therottenjohnny
6.7 Cummins diesel
(ES33) Legacy Great Funnels Flex 1.5 Quat 17 Inch Legacy CF This one has screw caps on the end that won't make a mess!!!
Tach_tech
5.7L HEMI
Check with your jack tools, they come with a funnel from the factory.
joshhhh
