Adding Suspension Airline Dryer
Xsen
Urals, Russia
Hey everyone,
Been thinking of writing this last fall, but decided to actually test everything first. Well, one winter later I can confirm that it works perfectly fine! So.
I hope this will be useful for anyone driving a truck with air suspension, who wants to keep it that way and not convert to regular springs. That was exactly my reason to do this mod.
Also, a disclaimer, I am not the original mod inventor, so all credit should go to Shezl (that’s how he’s known at Drive2 website). I just took my time to do this write-up. And yes, do it at your own risk.
The basic idea is this: troubles with air suspension that cause the truck to suddenly fall on one or more corners or get stuck elevated during low temperatures are most often caused by moisture in the airlines. Once the passage freezes, it blocks the air until the ice block melts, hence the fact that a night at a warm garage might heal the suspension. Till it freezes next time.
The Gen4 Ram air suspension is not exactly a closed circuit, though it does recycle the air a lot and uses the air tanks under the truck bed to store the air under pressure. However, there are times when the air volume needs to be increased or decreased significantly, i.e. when you load the truck, so the system may take some air in or purge some out. This is just to illustrate the fact that regular outside air (and moisture!) can be introduced into the system.
So, what we need is making sure that the air in the system is kept dry at all times, regardless of whether it’s stored in the tanks or sucked from the outside. The simplest way of doing so is installing an air dryer and running the air through it. On a Gen4 Ram there is only one place, where this can be done without triggering a DTC in the suspension control module – that is the supply line from the compressor to the tanks.
Here’s what we’ll need:
1. One WABCO 4324102227 air dryer cartridge or any similar unit, like this:
2. Two fittings 6mm – 1/4 , something like Camozzi 6512:
3. Seven ft (2m) of a 6 mm plastic frost-proof air line.
Here’s the hard part - this mod requires some fabrication, namely a plate adapter that we’ll use to connect the air dryer cartridge to the air lines. This can be fabricated from either steel or aluminum, I used the latter to save weight and skip the painting part. Here’s the CAD of the plate for the WABCO cartridge that has M39x1.5 thread.
All dimensions provided on the drawing are metric!
Speaking of the installation it’s nothing especially challenging and can be easily done by a DIY mechanic with basic skills. A 4-point lift is a great help too, though not mandatory. Here’s the routine:
1. Remove the F50 fuse from the fuse box under the hood, to disable the air suspension control unit.
2. Lower the spare tire. Wash, if needed. :D
3. Raise the truck on a lift or jack the rear right wheel, take the wheel and the wheel liner off.
4. Take the plastic shield on the rear side of the wheel well to get better access.
5. Take that stone shield thingy off the compressor.
6. Looking at the air tanks from the wheel well you’ll see this:
The red boxes on the photo mark the connection points for the nitrogen filling equipment. The green box marks the line that you need to disconnect.
7. Open either of the plastic caps, marked by the red boxes. Using a Philips screwdriver or a similar tool press the tip inside the connector to release the pressure in the tanks. Be careful, this will cause lots of dust flying around, so you might want to cover your eyes and face. The tanks are connected, you don’t have to do both connectors. Notice that your airbags would still be pressurized, so the truck could stay level. Once all the air is out, reinstall the plastic cap and move on to the next step.
8. Using a 12mm wrench unscrew the airline from the tanks. Do not apply excessive force here, it goes out pretty easily.
9. Get the other end of this line out of the compressor.
The yellow arrows point at the airline, and the green arrow points at the fitting, that you need to remove.
10. Carefully remove the factory fittings from the airline. Insert the airline that you’ve bought into the fitting, leaving about 3-4 mm, not more, sticking out of the fitting.
11. Re-install the fitting with the newly connected airline to the air tanks bracket. Again, be very careful, the bracket is made from plastic. Tighten the fitting, and give the airline a firm pull to properly seat it in the fitting.
12. Route the airline to the spare tire mount point. There’s a convenient place to pull the line out of the frame right next to the plastic tube. Mark this line with a piece of electric tape just to remember which line goes where.
13. Cut the airline, leaving about 2ft hanging.
14. Reinstall the factory fitting on another piece of 6mm airline and install this fitting on the compressor side. I failed to take a picture of this step, but I think you’ve got the idea. Don’t forget to pull the line to seat it. Route this airline to the spare wheel, out the same hole and cut the line about 2ft down from the frame.
15. Install the Camozzi fittings onto the plate adapter. Do not overtighten, or you might damage the o-ring on them. Stick the airlines into the fittings till they stop and give them a firm pull, they should stay in the fitting. At this point you’ve completed the airline assembly.
16. Get the spare tire back on its cable and let it hang on it. If you’re working on the ground, let it just lay there.
17. Install the WABCO cartridge onto the adapter plate, cover it in something soft, like a few layers of fabric, etc. and put it into the spare tire. The airline length should be more than enough. This is the easiest way to keep it, lowering the spare once or twice a year for cartridge replacement, and the fabric would keep things quiet, but you might also consider fabricating a bracket for the adapter plate and fixing it somewhere on the frame nearby the compressor, there are a few options.
18. Reassemble everything from that stone shield to wheel well liner and the wheel, pull the spare up and lower the truck.
19. Put the F50 fuse back and start the engine. Let the compressor pump the air into the tanks.
That’s it, now you have a dryer in the system, that will keep it moisture-free under any conditions. Time for a cold one.
A few words on the nitrogen. The service manual says that you must use 99.999% nitrogen to fill the air suspension system. This might be a great idea, and if you’ve got a tank of nitrogen – just connect it to the tanks after step 17 and fill it up until the pressure reaches 12 Bar. But then again the system is not closed-circuit, air may enter and leave the system, so… You’ll have to decide for yourself. I filled it with regular air last fall and had zero issues, so that’s my 2c.
After you install this mod it’s quite recommended to operate your suspension in an active sort of way, several drives each day, running the height up and down, etc. Warm weather also helps.
In fact, late spring would probably be the best time for the mod, you’ll have plenty of warm weather to dry the air in the system until next colds come.
Daw14
South Florida
This should help a lot of people who have been dealing with this issue , thanks for the great write up !
wes8398
Ontario, Canada
Holy ****; this is amazing. Being brand new here, I don't intend to rattle any chains... But don't mods "sticky" awesome posts like this for everyone else to easily access? And OP - did you happen to make the adapter yourself? If you have the tools and know-how, I (and I would suspect many others) would be more than happy to pay you handsomely for a little "production run"... :D Or... would there be any issue with getting an air dryer adapter plate from something else, and just adjusting the fittings to work with our sized lines; so to avoid having to machine/make our own special adapters? Something like:
Or... I wonder if a "water trap" would be enough for our application. Something like one of these: https://www.bagriders.com/air-management/water-traps.html
MADDOG
Living in a Firepit
We went well beyond adding "stickys" for threads like this. We added an entire section in each generation forum for these awesome DIY posts.
savage_46
Alaska
6.4 swapped
This is genius. Keep us updated if you make through a few cold snaps with no issues
Xsen
Xsen
Urals, Russia
Thanks! I had this installed and running since Oct 2021, so it has been tested in all temps ranging from around 0C to about -35C, all worked fine!
Thank you! I had a small machine shop make the adapter. I could do a small production run no problem, but shipping would be hell at this time, I think.
In fact you could go with the adapter from that link, just customize the fittings. Stock airlines are 6mm, so I'd stick with that size.
savage_46
Alaska
6.4 swapped
Do you know what p/n version your compressor is? AK or newer?
Xsen
Xsen
Urals, Russia
Not really. Does it have the p/n stamped anywhere on the compressor body?
JoeYesbut
Canada
Ecodiesel
Hey! Pulling this thread up. I would like some follow up on the solution if anyone else has tried it.
On my end I found that purging the whole system with fresh nitrogen each fall also helps, but the dryer might be the right finishing touch.
Thanks y'all
Xsen
Xsen
Urals, Russia
As for me, I'm preparing to change the cartridge somewhere in September and roll into my second winter using the dryer.
wes8398
Ontario, Canada
I can't believe this type of solution hasn't caught on with the community at large. Seems to be the most reasonable and effective way to keep your air ride.
PaleFlyer
Charlotte NC
Thanks y'all
That's what FCA wants you to do... As most of us probably don't have access to that kind of N2 source. What OP did is 100% inline with this forum.
Fixing all the **** FCA dropped the ball on.
(I am aware that Fiat only bought Chrysler around 2015, so a lot of the vehicles here are actually pre-Fiat. But... Same/same, only different.)
Xsen
Xsen
Urals, Russia
Here's the PDF file containing the CAD drawing for the adapter. Thanks to the fellow member for pointing out that PNG drawing is far from perfect for upscale printing. Hope noone minds the cyrillic writing on the CAD.
  • Air Dryer adapter.PDF
zrock
canada
One problem i see here. Unlike the trucks that these air dryers were designed for where the compressor is constantly running and air is constantly being used so the filter is working as designed. On our trucks if the air system is working properly the compressor will kick on very little if at all sometimes. Also Putting this inline between compressor and tanks does not solve the problem since its not the tanks freezing up its the moisture in the compressor freezing up from condensation from going to a warm compressor to cold. Also air dryers filters are designed to work in one direction so if the compressor is pulling air from the tanks instead of filling its doing nothing but bypassing filter. Also these filters only dry the air coming from the compressor in the veh they were designed for, You still get condensation in the air tank from warm are that is cooling down, this is why yo see truck drivers constantly draining water from their air tanks..
Good idea and may help some but not cure the problem.
Xsen
Xsen
Urals, Russia
This line is the one that would not throw a code if you make changes, as the controller does not care about the volume here.
What I've been seeing around here is the problem when one of the lines going to the actual air bag freezes and the truck drops on one or two corners. So whenever you add the outside air to the system - you have to dry it out, and then there would be no moisture in the system to freeze. In other words I don't see how would there be condensation in the tanks, if the air was run through the dryer to begin with.
Anyhow, this works for quite a few Rams on this side of the globe, though I by no means insist that this is the silver bullet.
wes8398
Ontario, Canada
You raise good points, but...
The intention here isn't to employ the air dryer exactly as it's intended application. We just need to dry ambient air when it's being brought in to supplement due to a leak situation.
But you're right that once/if the system is void of most or all of its nitrogen, movement from bags to tanks and vice versa could still add moisture post dryer if the dryer is only filtering incoming ambient air.
bm02tj
B C Canada
I use a Wix ACK10 for the air lockers on my Jeep as water is not good for them as well
zrock
canada
From experience and reading its not moisture in the lines freezing, its moisture in the actual compressor that is freezing hence why it blows the 40 amp compressor fuse. Only way to sorta remedy that is have it ingest some air line anti freeze automatically instead of having to remove the rear tail light and adding it that way..
Myself i have not seen posts about airlines freezing just the compressor and distribution block attached to compressor.. Not saying it does not exist.
wes8398
Ontario, Canada
I don't think you're fully informed, to be frank.
