bryce88
Hey everyone, I think I've found a REALLY good solution for anyone looking to upgrade quad reflectors and fogs to LED on a budget. They look exactly like the supernova v3 from headlight revolution. Maybe they're even from the same factory in China? Who knows? The drivers on them are also IDENTICAL down to the green sticker, as seen on the Headlight Revolution installation videos.
Anyway, they're $50 a pair compared to $180 a pair from Headlight Revolution
Link to the budget LEDs:
VK-5S H11 H8 H9 8000LM LED Headlight Conversion Kit, Low beam headlamp, Fog Driving Light, HID or Halogen Head light Replacement, 6500K Xenon White, 1 Pair https://www.amazon.com/dp/B01FI0S49U/ref=cm_sw_r_cp_apa_fmCxBb90B9B84
Link to Headlight Revolution Supernova V3:
https://headlightrevolution.com/200...led-h11-low-beam-bulbs-upgrade-supernova-v-3/
You will need the PWM modules if your truck is 2015+ I believe. When I first put them in they turned on and off intermittently and weren't consistent. I added the PWM modules and now they're perfectly reliable. Here's a link to the ones I got at $15 per pair:
https://www.headlightexperts.com/li...odulation-module-for-led-and-hid-applications
(The kit from Headlight Revolution comes with PWM modules)
I went ahead and put the Vouke VK-5S in my low beams high beams and fogs.
If you don't know, for the quad lights you'll need:
H11 For low beams
9005 for high beams
9006 for fogs (double check this for your truck)
So, if you do the math to upgrade all three sets:
Supernova V3:
$180 x 3 = $540
Vouke VK-5S + PWM modules
$65 x 3 = $195
Pretty substantial savings for what, in my opinion, is pretty much the same system.
Here are some pictures to give you an idea of the performance you can expect:
Photo 1: Original low beam halogen pattern for comparison
Photo 2: Vouke VK-5S LOW low beam pattern
Photo 3: low beams + fogs on road
Photo 4: low beams + high beams
Photo 5: low beams only
Photo 6: Vouke VK-5S bulb
*Note - the color difference between the on road photos is not real, my phone did weird things to the color. The most accurate color is the photo of low beams + fogs
Let me know if you guys have any questions!
H11 For low beams
9005 for high beams
Supernova V3:
$180 x 3 = $540
$65 x 3 = $195
