After losing all coolant from blown water pump hose truck won't start.
rick schelin
montana
2008 5.7 Hemi won't start after hose failure and lose of all coolant.
Truck has 12v at battery and fuel is getting to Schroeder valve but vehicle does not start when cranking.
20A Battery ignition fuse was blown and replaced.
Sprayed starting fluid in throttle body and nothing happened.
Later2u
West Coast
Check for spark.
As easy as pulling a plug wire and putting a spark plug on the end, have some one crank the engine and see if you have spark.
Karlsweg
SW Florida
Hopefully it didn’t overheat and drop a valve seat!
Marley
VA
Antifreeze likely blew into a connection.....same thing happened to me going through deep water.
Clean soaked connections and little dab of dielectric grease.
UNLESS you overheated the engine to the point of failure.
HemiLonestar
Navy Badge Coast Guard
MD
Did you check the ASD relay?
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
If he has fuel pressure the ASD relay is working. Injectors , coils and pump run off the ASD relay with injectors and coils sharing the same 12v supply wire.
Redtruck-VA
Virginia
You might try holding the throttle pedal to the floor while cranking the motor.
topherztoyz
