Air bag light on. Question About clock spring replacement.
Werld99Ram
5.2 magnum
So, im sure the clock spring is a common thing talked about on this site. My question is simple...
Ive got a 99 dodge ram 1500 5.2 magnum with no cruise control....
cost of clock springs are completey reasonable until you get to the ones flr trucks without cruise control.... can i buy a clock spring for a cruise control truck and put it in and be fine?
C2ndLTpigeon
California
1999 Dodge Ram 1500 Sport
5.2L
Yes you can use a clock spring with cruise if you don't have cruise, you will just have no need for the cruise control wires just tuck them out of the way. Be sure that the clockspring is set in the correct position or you might have to do the reset turning sequence.
