Air bags to increase pay load
Hunter Rob
calgary alberta canada
6.4 hemi
Hi. im getting a 2022 PW soon, just wondering about good and bad on putting on airbags,next year
i want to put a camper on for hunting and fishing trips. I need to pull my quad or a boat.
please let me know what you think.
Thanks
OC455
Central NY
Air bags will not increase your payload. They can help with leveling and stabilizing your carried load. That's about it.
BowerPower
Arkansas
If by "put a camper on" you mean one of those slide in campers, the power wagon comes with specific instructions not to. It can be done, I saw one in town yesterday didn't lean or sway around turns. If you mean a topper thing to enclose the bed then ignore that.
Legally speaking, air bags can not change the door sticker payload unless it were to be recertified. Luckily for us there is no law (that i have found) that says you can't go over that number. If your truck is sagging badly, swaying, etc. while hauling stuff the police can sight you for that. Highway police look for over loaded axles. Axle rating on this truck is 9000 pounds or so in the rear.
Real life example of the payload silliness on a power wagon. One time I had 4 adults in my truck and a big cast iron furnace thing. If I had to guess the weight of the adults 2 were 250lb and 2 were 300lb, the furnace weight 500lb, add that up 1600lb. Subtract 150lb for the driver that is calculated into payload rating for a total of 1450 of payload, if I remember correctly for my truck that's over weight, yet it didn't squat a whole inch. It's a heavy-duty truck! How can 4 adults and a little weight in the bed over load it?
thkbaron
Minnesota
There's plenty of smaller slide in campers that people toss in power wagons. I believe most of all of them are using bags though.
H
Hunter Rob
6.4 hemi
Thanks for the feed back everyone
The camper im going with is 8ft 11inch and about 3200lb dry
So with airbags im sure the will sit level and drive decent.
I put airbags on my half ton and what a huge difference towing big
trailer with 8ft flat deck on the front with quad on it. Had no sag
at all.
Time to move up in the world with a new PW
dhay13
At 3200lbs you will be way payload and likely GRAWR. Check your GRAWR on your door sticker. Probably 6000 or 6500?
retired
montana
no way in hell should you put a 3200lb camper on. you are in 3500 territory. Air bags will not make it safe to carry a 3200lb camper. figure by the time you get you and a passenger and your gear you will be over 4000lbs...
H
Hunter Rob
6.4 hemi
Just had to recheck the camper specs. and its between 2600 to 2800 lbs
not 3200lbs sorry about that guys
Not sure if that makes any diff. but thats why im on here to ask some pros
before i get one.
I really appreciate your advise... thanks
Dinky
Oregon
before i get one.
392DevilDog
Glasgow, Pennsylvania
392 Hemi
If you are buying a PowerWagon and do want a slide in camper...these are the people you want to talk to.
Dodge trucker
Kankakee il
My '12 1/2 ton came with airbags on the rear axle installed by a PO. They are completely flat right now I haven't had a need yet to air them up and see if they hold.
andymax
Central Ohio
The debate should not be about "legality"...the real issues are safety and insurance. There must be a viable reason that RAM derates the payload on a power wagon...surely it has to do with the off-road suspension.
More importantly, don't think for a second that your insurance company won't investigate whether the vehicle was overloaded if you get into an an accident, especially if there are any injuries. Sure, they might cover the accident, but you will be dropped immediately and good luck finding a new company to insure you. I believe this based on an in-depth discussion with my uncle who spent 12 years in claims investigation at "Flo's insurance company".
There's this huge misconception that airbags correct the weights distributed between axles...they don't. They only level...giving one the appearance of not being overloaded. Not the case.
Not convinced? Google this phrase: do airbags increase payload?
Arturo Rojas
