Air Lift Load Lifter 5000 rear bags question
Phylodog
Arcadia, IN
2012 & 2018
5.7 Hemi & 6.7L CTD
I ordered in the rear bags and remote controlled compressor which I intend to install on my 2018 2500. I have already installed the Thuren Overland kit which raised the rear by 1" and the front by 2.75". The thought just occurred that I may need a spacer to use the rear bags but thought I would ask if anyone else has run this combo? Air Lift sells a 2" spacer but no 1" so I'm not sure which way to go.
Anyone done this and can advise?
Thanks in advance
G. Mcpherson
Vancouver, Wa.
2023 Ram 2500 CC SB Tradesman
Might want to look at installing DayStar Cradles. No travel restrictions.
olyelr
Kewadin MI
Yea, if you have Thurens kit then definitely get the daystar cradle setup. Otherwise you could possibly damage the bags and/or limit suspension travel.
Also, you will be fine with no spacer. My power wagon rear springs are the same height as Thurens, and I even took the factory 1” power wagon spacer off.
Heres a writeup I made when I did mine. May help you out...
http://forum.powerwagonregistry.org/viewtopic.php?f=45&t=4732
Phylodog
Phylodog
Arcadia, IN
2012 & 2018
5.7 Hemi & 6.7L CTD
Thank you Gentlemen, I'll order a set of the cradles.
Bldrinker
what thread tap and bolt did you use. I’ve never taped threads before so I have no clue.
olyelr
Kewadin MI
I honestly dont remember the size. I cant remember if the bolts came with the daystar cradles or not. I think I just went to the hardware and grabbed a bolt that was as big as could be yet still fit in the hole. Then bought the tap that fit that thread size.
olyelr
Kewadin MI
Yea, I looked at the pics in my writeup, the daystar kit came with bolts and nuts. I think I just went to the store and got the correct size drill bit and tap for that bolt.
ChloeBrooks
