Air suspension
TerraNewf
NL, Canada
I just recently noticed that my suspension loses air in the front while parked overnight. No lights or warning signs, has anyone with the air suspension have this happen? Thanks in advance for any replies.
TerraNewf
TerraNewf
NL, Canada
Guess nobody has air on this forum. Thanks for the help
BWL
Embrace the skeptisism
BC Canada
You likely have a leak. It shouldn't drop at all. Mine sits all the time for weeks and never drops.
BWL
BC Canada
Sooner you address the leak the better. It's a closed nitrogen system to keep moisture out, but will draw in air if it needs to in case of leaks. Problem with that is with fresh air comes moisture and all the cold weather and corrosion issues. Once the leak is fixed there's a fairly complicated procedure to purge the system and recharge it
TerraNewf
TerraNewf
NL, Canada
Thanks guys, I wasn't sure if it was normal or not. Time to take it to the dealer, it's still under warranty
oe542bob
Hemi eTorque 5.7
Definitely not normal. Have had 4 Grand Cherokees and 2 Ram 1500s with air suspension. Haven’t had any leak down issues.
Virginia Beach, VA
2020 CC 4x4 Longhorn Offroad
I have he air suspension. Mine will randomly pump back up and relieve while is parked and turned off
