air suspension
dr012
I am considering the purchase of a 2018 Laramie Longhorn with air suspension. Is this system overly trouble-prone? Should I be looking at something else?
CanuckRam1313
Ontario Canada
2023 Warlock
Another vote for stay away from the factory air suspension!
However, if the truck is solid itself and you like it, you can always get the conversion kit to go to normal suspension, and maybe talk them down a bit on the price to help compensate for the known issues with the factory air suspension.
LouM
Marine Corps
Greeenwich/Easton upstate NY
2015 Ram Ecodiesel crewcab old/ 2019 Laramie Hemi old/ 2022 RAM 2500 6.7
eco diesel old / now Hemi missing the eco's mileage/ now back to enjoying diesel torqueesel
My 19 Laramie has been trouble free from the air suspension, and except for com issues from a dead battery almost no bad issues of any kind.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
The OP is asking about a 4th gen 1500. The air suspension system on 4th gens seems to have been much less reliable than the updated system on 5th gen 1500's. Assuming your '19 Laramie is a 5th gen, it is not surprising to me that you haven't had any issues with your air suspension.
DA67Goatman
Ohio USA
It has some design flaws that tend to show up more often if your in high humidity or freeze prone areas. I for one would gladly buy another with air suspension, ride quality can NOT be beat.
mikeru
Super Moderator
Eastern WA
2020 Limited
Having owned 4th gens and 5th gens both with and without air suspension, I don't see that the air suspension makes ride quality better. Choice of tire will make more of a difference IMHO. I like having air suspension for other reasons, like ride leveling while towing (within payload ratings of course), dropped down for easy entry and exit for the shorter passengers, and lift it up to OR2 for working under the truck on a creeper without the need to jack it up or use ramps.
LouM
Marine Corps
I went from a 15 loaded Tradesman to this 19 Laramie, I've been pleased with both of them. The 19 with the air suspension does ride nicer then the 15 with regular suspension ( yes, I know it's different generations). I have the Offroad group in mine so I only have 1 offroad height setting.
Nick@GotExhaust
Supporting Vendor
SC
The 4th gen RAMs air suspension has shown to be problematic, especially in colder states. If you live somewhere that gets cold and often I would definitely stay away from it.
jws123
nj
Just plan on switching it out for regular struts/shocks they make kits for it.
DJack
