Following... Does AlfaOBD have a 'save' configuration option to back up the existing config before making changes?
Compare your original bcm upload with your truck at factory to a new upload done right now.
Compare and you will see the differences. You must have changed something on accident. Change everything back to factory.
This right here is why you always have your factory BCM config. Along with RF hub etc.
So is Yes = 1 and No = 0? When it shows a setting as ' NO ' -> '1 ', does that mean the setting was changed from 'NO' to 'YES' ?
Ok, first thank you all. Appreciate the input. I checked my batteries, 2.5 years old, tossed in some new ones since I disconnected. The truck sat for three hours. Reconnected batteries, also reconnected dongle. Went back and carefully checked everything and corrected the DRLs. Went through the codes and eliminated them, and everything works. =-D Learned my lesson the hard way. Thank you again all.
