I have a Laramie 2016 4x4 2500 Diesel.
I have multiple errors, two of which must be my fault, and the ABS and Trailer Brake Error, no clue how these appeared, never happened before doing this today. I did read where others who had a trailer brake error could not clear the fault, and this is why they bought the ALFAobd, but I did not have that error until after programming.
I just programmed my fog lights to stay on with my high beams and they work great as supposed to.
I carefully read (including the 790 page plus post here) and watched videos and wrote down everything I did. I then tried to do the daytime running lights on, and they did not work. I returned the settings to the original settings on the ALFAobd. Each time cycling car on/off and waiting 30 seconds min.
I am running Android/with the correct bluetooth obd port, brand new, connects and works fine with ALFAobd
Question: I am assuming there is no hard reset to the ALPHAobd to return things to normal and this is going to now be an expensive trip to Dodge.....
Any help appreciated.
Attached is the report I ran and cut and paste together with the ALFAobd, it's a long one.
I now turn on the truck and I get a few errors I never had before:
Trailer Brakes Service (this shows up now as a service light with no error code)
ABS Service (this shows up now as a service light with no error code)
4x4 will not engage (flashes only) (this shows up now as a service light with no error code)
Speedo is dead - three dashes only (this shows up now as a service light with no error code)
Temp gauge is dead (this shows up now as a service light with no error code)
These two codes show up in the ALFAobd
B181E
Hood Ajar Iput
Open circuit
Last test completed unsuccessfully
Error present
Failure warning lamp 'ON' Not requested
B16B7
Center stop lamp control
Short circuit to + battery/Open circuit
Error present
B181E
Hood Ajar Iput
Open circuit
Error present
B16B7
Error present
