alfaobd + forscan ELM 327 usb
l3_jok3r
Bromont
Hello, I'm trying to connect with a Forscan ELM 327 USB on AlfaOBD, but the connection doesn’t seem to work. There is some data transfer (the lights are blinking), but no readings. Could you please confirm if the Forscan ELM 327 USB is compatible, and if not, which reader would you recommend? Ram 2500 2014 ( I cannot post on the gen 4 )
RamDiver
Marlborough, Ontario Canada
2021 DS
I tried one of those devices and wasn't satisfied it was adequate for the task.
For AlfaOBD for windoze I use an OBDLink SX.
For AlfaOBD for Android, the preferred device is the OBDLink MX+.
And, welcome to Ram Forum. :cool:
PS: The OBDLink SX appears to have disappeared from the amazon dot com site, but is still showing as available from the dot Ca site. For purchasing in Canadastan, the SX is $75 versus $210 for the MX+.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Or the MX+ with windoze.
Those cheapie Elm327 dongles usually don't work because they don't have bi-directional comms / commands. They can normally only read, but not write except to clear a code.
PS: The Forscan is the Ford comms protocol / works best on Fords.
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Straight from AlfaOBD website...
L
l3_jok3r
Bromont
I try with a OBDlink Ex and still not working, I got ''connect'' when I use the manual connect 11bit/500k option but I cannot read the error code or nothing else
04fxdwgi
2016 1500 Sport
Later on this AM, I will go out and connect my MX+ up. I will take some screen shots to show what the setup / connection mode looks like on my PC. .
Those numbers you are using / posting are no where near correct.
04fxdwgi
2016 1500 Sport
Here are the settings that work on my PC with AlfaOBDm and the MX+. Connect 1st time / every time.
If using bluetooth, be sure the interface you choose is "Bluetooth ELM327//OBDLink LX/MX/MX+//vLinker"
RamDiver
2021 DS
Something in your configuration is not correct. 'Device model not detected'.
Show a screenshot of the Start tab while in Regular mode.
RamDiver
2021 DS
When I look at that screenshot, there isn't an ECU selected, nor does AlfaOBD appear to be connected.
In your previous screenshots, 'Device model not detected' is a notification of a configuration or hardware error.
Is there any reason that you're choosing to connect using Advanced Mode?
RamDiver
2021 DS
I found the issue...I have to chose the ecu
You don't appear to understand how the process of solving problems online functions.
You're new, so I'll share.
Many members volunteer their time to assist those who are looking for solutions.
We do our best to find the easiest, shortest and most cost-effective results.
We frequently ask questions to support this action and also to provide context and information to other future members who are searching for answers.
And, we are doing our best to remotely solve problems.
All we ask in return is for a full disclosure of the faults and open communications that include answering questions. This format has been very productive for many years.
Please be a team player and contribute by answering any questions posted.
Thanks in advance.
Fatboy1989
