AlfaOBD
mxrider309
memphis
just got my hd fire 8 today and purchased the software (alfaobd) and trying to download and just says downlad pending??
help... thanks
chrisbh17
help... thanks
Android os or play store may be updating in the background. Try rebooting.
Sent from my Nexus 6P using Tapatalk
Gibbs
GA
6.7L Cummins
I just got done installing an auto dimming rearview mirror (can't believe my Bighorn truck didn't come with one). Shhh...my truck is sleeping right now...
I changed the following:
Interior EC Mirror Present--Yes
Program Customer Features,
EC Mirror Auto Dim--Enabled
Anything else I need to set? I couldn't find a CSM for EC Mirror, which I figured it needed to add the soft key to the radio.
bhiii
#justsaynotochrome
USA
6.7L Cummins
I took the cheaper route and did always dimming rear view mirror and put 5% tint on top of the factory tint.
chrisbh17
Weird, my big horn came with auto dim. I thought it was part of the big horn package
Gibbs
GA
6.7L Cummins
Apparently my truck has a weird combination of options. Heck, even my Tradesman had auto-dim!
Pucknuts
Central Oregon
Usually when the ambient temp sensor is defective it defaults to negative 40゚ the first thing I would recommend doing his disconnect the battery cables and touch them together wait for around 20 minutes in reconnect them it may reset for you.
All is good after a 20 min no-power nap! Thanks
Sent from my SM-N950U using Tapatalk
1500ram12
5.9L Cummins
no good, now cant logon back in play store , its in some type of loop
Did you download a playstore apk to install the playstore
mxrider309
memphis
restored the tablet and removed storage card and installed to device and now it download software
I will only be using this tablet for this.
thanks again for help. now just need the bypass cable to and good to start working on truck
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Ok all, whats this?? Threw a check engine light.
This is a pic from my alpha
Ramm5.7
So Cal
https://www.dtcdecode.com/Dodge/P1DCA
https://www.autocodes.com/p1dca_dodge.html
I'd clear the code and try a reset/replace on the rf hub
Thanks 1500! I cleared code already and now Im having issues with my multi switch not working. Parksense works fine while parking still but have no button control to turn em on or off as well as traction and tow haul. Like no power to switchs so must be a ground issue!?? After clearing code 2-3 weeks ago the switchs slowly started to stop working intermittently but now not at all
busterbrown
Detroit, MI
2017 Ram 2500 Megacab Laramie
The three functions I wanted to change/add using AlfaODB were successfully executed today.
1. Added the flip up mirror position correction (for tow mirrors I installed).
2. Changed TPMS thresholds to 50 PSI for fronts/rears
3. Activated DRLs (via LED turn signals.
However, even though the DLRs are working, I don't see the option to turn them "off and on" in the 8.4" settings screen. I made changes as described in post 150. Do I have to wait a few ignition cycles for it to appear. Or do I have to reset the radio to factory settings? I did turn on and off the truck about 8 times in a period of 20 minutes or so. Confused...
1500ram12
5.9L Cummins
Some people has said it's taken a day for it to show up. Did you go into program customer features and turn it on
WilliamS
Tampa FL
Has anyone been able to confirm what’s needed for the tilt in reverse to work?
busterbrown
Detroit, MI
Yes, I did. I'll wait till tomorrow and recheck the radio menu and the AlfaOBD settings. There are so many options to filter through in the "car configuration change" menu. Pretty sure I updated the right ones.
Ricks Ram
In doors section
Drivers side mirror memory (Yes)
Passenger side mirror memory (Yes)
Tilt in reverse in the custset menu.
(CSM) (Yes)
One thing to note is the (Tilt In Reverse) function will not work unless you have memory mirrors. You need to have more than 4 wires in the white mirror plug.
Ramit2016
Chesapeake, VA
Did it a few months ago. Picked up a set of OEM chrome cap tow mirrors. I'll have to check what exactly I enabled but I think it was only memory door modules and the feature itself. I also got the memory seat module to work. Setting 1 is with my mirrors down, 2 is when they are flipped out
