AlfaOBD
1500ram12
5.9L Cummins
Good thought in the battery. So you did switch the settings over to LED? Then let each side run for a bit?
Yup
2018 2500 6.4L Tradesman
hougie
canada
Do you have a 2500/3500? What year do you have?
You are selecting BCM, active diagnostics, then update pressure thresholds correct? The process was slightly different for my 2012 and it took me a couple tries. On my 2012 the light went of immediately once the BCM accepted the changes, but with other years it may take some time or driving around for few miles for the light to go away.
If you have a 2500/3500 with the light load button on your panel... Look at: BCM, active diagnostics, car configuration change, select option, then scroll down to vehicle config 4. In the vehicle config 4 options there are 4 settings for max load and light load settings.
I'll wait to hear what year/model before I go off more on the max vs. light load in case you don't have that option.
I have 2017 ram 2500, no light load button in truck. I'll look in BCM and see what it says. My evic says to inflate to 63psi but that doesn't make my light go out . I drive it on the highway for 15 minutes to check it.
Dantra
Martinsville Indiana
Be aware!
Some of these settings obviously carry over from other vehicles lines and setting them randomly can cause serious issues with the truck working. There have been some settings that when changed actually turn off/on multiple settings and can be very difficult to find out what happened and undo it.
This has happened to a handful of people early on (can't remember who) and they either had to take their truck to the dealer or it took them several days or longer to chase down the changes by comparing their original settings.
*** Make sure you create/save a backup text file of your original BCM config (ie gDrive) before doing anything ***
M² Mods.
I appreciate your concern sir! I'm not brave enough to try any unknowns with the Alfaobd as i am new to it. I changed some light setting for LEDs and Low Beam Drop Out.. watched youtube videos to walk me through and took screenshots of what I did. I do need to figure out the gdrive before attempting anything else. Next on my list is disabling the damn Panic Alarm.. hate that damn thing.
Bill507
New Orleans
Just successfully set LED fogs to DRL. Love this tool.
Sent from my rotary telephone using Tapatalk
hulk181
wisconsin
Did you change your mirror to one that is Smart Beam capable? What mirror did your truck come with originally? Depending on your original mirror, you may also need a different harness that goes to the rear view mirror.
I did switch out the original non-camera mirror for one with the camera. The connection was the same as the original mirror. The auto high beam option did show up in uConnect after I did the steps through AlfaOBD. Again something is causing the tailgate with these steps to stay locked. After I revert the steps then the tailgate works. I'm debating if I should try one step at a time to determine what is causing the problem with the tailgate. This is on a 2019 1500 Bighorn. Any other suggestions?
mjf6175
NJ
cummins
Where did you source the Smart Beam mirror from? Bought new or from a salvage yard? If new what was the part number? And if salvage yard, can you post a pic of the back of the mirror. Unfortunately salvage yards are notorious for misidentifying Auto-Dim mirrors for Smart Beam mirrors.
I added a Smart Beam to my 2017 Ram 2500 but had no issues. I did all of the changes in the BCM at the same time.
See post #7086, page 709 this thread, link below for reference....
https://www.ramforum.com/threads/alfaobd.123982/page-709#post-2032282
hulk181
wisconsin
I bought the mirror online new from SummitRacing.com
MOP-68312206AA
MIRROR, INSIDE REAR VIEW, 2019-2020
(Mfr. #: 68312206AA)
It looks the same as the one in the link you posted.
chrisbh17
MOP-68312206AA
Do you have the security bypass harness in place while trying to make the changes?
Txdodge68
Just a quick question, I just bought a Galaxy Tab A that I was going to download AlphaODB on to so that I can use it on my 2014 Ram Express. Will this work okay on this tablet the only reason I ask is that on the google play store it says that the app may not be optimized for my device. I would hate to download it and then it not work right. Any help would be appreciated.
Chino Valley, AZ USA
2019 Classic Crew Cab
You can download the FREE Demo Version to ensure that it will work.
RodeoGeorge
hoe...
It works fine on my galaxy tab a.
That warning is probably due to resolution not being optimal.
Sent from my VOG-L09 using Tapatalk
TonyMM
2016 RAM 1500 CC 6"4 4X4
I also have a Galaxy Tab A and AlfaOBD works fine on it.
Txdodge68
Thanks everyone, first mod will be upgrading to power folding mirrors.
Sent from my SM-T380 using Tapatalk
mjf6175
NJ
cummins
I am using the 2018+ FCA Security Gateway Module Bypass from Infotainment.com.
hulk....the only thing left I can think of is: what dongle are you using to connect to the BCM? The MX? In fact is your AlfaObd program on an android device or a computer running windows?
chrisbh17
Pretty much what I was left with wondering.
The fact that the tailgate lock actuates at some point makes me think the OBD adapter in use might not be fully compatible for writing to the BCM, and/or not fully compatible with the infotainment gateway.
hulk181
wisconsin
I am using the BAFX Products BAFX3127 OBD from Amazon and am running AlfaOBD on my Samsung Galaxy Note 10+. I went with this OBD and security bypass because I saw elsewhere that someone used this combination to install a brake controller successfully on a 2019. What OBD would you suggest to try instead?
noraa73
