Ricks Ram
- May 1, 2015
- 4,411
- 3,388
- 2014
- Hemi 5.7
That would be awesome if that was the case. I hope someone knows and will respond to your question.Hey, what's that "erase ignition fobiks"? Did I miss something? Can we wipe and reprogram used fobiks?
It's probably not for the keyfobs itself but to remove them from the RF hub recognizing them. This would be in case a keyfobs was lost/stolen to keep unauthorized use of the vehicle.Hey, what's that "erase ignition fobiks"? Did I miss something? Can we wipe and reprogram used fobiks?
Sorry but how do I get to RF hub, I’ve looked in abs, engine and body control.
Unless I’m blind.
Getting your pin is also used to help change tire pressure thresholds right when changing tire sizes?
Phone dont need be rooted, only works with android not apple phones
Sent from my SM-N986U using Tapatalk
Ok, so I'm working on an 06 Magnum. I changed the tire pressure threshold, how do I reset the RF hub to get the light to turn off? I seem to remember seeing an option for it in the past, but I can't find it anymore. Thanks for the help!
Sent from my Pixel 5 using Tapatalk
I don't know what what means, I'm competent enough with technology but I'm by no means an expert. Could you please explain? Thanks!You might need to look at PROXI alignment. Ive never used it on a vehicle that needed it so Im not sure where the selection is, but I believe some different model/older vehicles like an 06 require it.
Don't see PROXI under any Magnum BCM. There is Vehicle Config2 Tire Pressure System Present with option for Set or Not Set.I don't know what what means, I'm competent enough with technology but I'm by no means an expert. Could you please explain? Thanks!
