AlfaOBD
pacofortacos
Has to be on your end. I just downloaded it again, working fine on their end.
Are you trying to download this?
August 2nd 2022: Version 2.3.6.0​
Various updates and fixes.​
NOTE: .NET framework 4.0 or later required for the PC version to run.​
pacofortacos
The above is the correct link and what you want to click on when on their site.
I just clicked on the post above this one link and it downloaded for a 3rd time.
You do have windows PC's and not chromebooks, right? :)
ajhudson15
Indiana
5.7l V8 Hemi
I can’t even get to their site. One I click the link to their site or tries to load and then I get the this page is not responding error
pacofortacos
I get the website did not respond check your firewall and proxy server error. I’ve tried this on 4 different laptops on 3 different internet connections with the same thing every time. I used to be able to get to the website but now nothing. I don’t get a more option to continue to the site
The more option was when running the .exe file not their website.
pacofortacos
Unfortunately it says unsupported file type. I’m not sure what else to check with my Internet. The fact that the site worked for several days and then stopped when I decided to download it lol
Did it download the file from google drive? Or wouldn't even download it?
ajhudson15
Indiana
5.7l V8 Hemi
I’ve tried chrome, edge, and Firefox. When I go to Google drive it just says file not supported. I don’t think I have any other blockers enabled. Like I said the website worked for several days before doing this and I never changed any settings in between.
pacofortacos
Got on my laptop
and accessed Google drive and it send to be working from there
?? Did you get it downloaded and installed then? If that laptop isn't the one that you want to use the program on, you might wast to save it to a usb and put on the laptop you want - so you don't have to transfer activation later.
UziDoesIt
Is there a way to keep turn signal DRLs on at all times. Problem I'm having is at night when headlights come on, DRLs shut off. Thank you!
Irongoats
Las Vegas
2015 Ram Sport
Turn off I can't get them to turn on haha. On one part of the test it says go to program features or something like that but it wasn't here.
SRich2015
USA
Anyone know if alfaobd will still work with a security bypass installed? It has you pull i think wire 6 & 14 from the OBD to install the bypass. Or do I have to replace the wires back in??
DoughRat19
Massachusetts
2019 Classic
Has anyone who has added the HD CHMSL been able to get the grid lines to show up? Was that even an option on the HDs that had the CHMSL installed from factory? I’ve got mine wired up correctly and everything works except I can’t get the grid lines to show up.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Mine doesn't have grid lines. I don't believe its possible on that camera. And really, why would you want them. The camera's view is inanimate.
DoughRat19
Massachusetts
2019 Classic
I had heard that instead of two lines on the side there is one center line that helps you line up a 5th wheel.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
I'll double check tomorrow but from this pic I have of my screen I don't see any. Can't see why you'd need a line to line up a 5er. I use the hitch to line it up.
DoughRat19
Massachusetts
2019 Classic
It’s just my OCD. When I add a factory option I want to make sure I turned on all the correct settings and it is working 100% factory. Not a huge deal just irks me if I think something is setup wrong.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Just quadruple checked, no line. I did add the option using AlphaOBD but since the camera is not designed to have it, the settings will not let you select it on/off.
Hunter Lyons
Cassville, MO
6.7L Cummins
Have a couple of questions I am hoping you all can help me with. I am trying the get my 18 ED tire size updated and I am running into some issues. I have deereguys bypass installed (thanks Deere :) and I am using android tablet with mx Bluetooth.
1. When I get to the step with clearing rolls information I am getting “Failed. Service not supported in Active Diagnostic Session.” This happens every time I get to this step.
2. When it says to clear codes for the ECM what engine do I select for the ED? Is it the Chrysler/3.6,4.6,5.7........
Being GDE Hot Tuned I assume it doesn’t matter since changes are being made to BCM and not the ECM is this correct?
Did you ever figure this out? I am currently trying to change my TPMS thresholds and I am getting the same failed message. Super annoying. I am on the windows version.
