gassersarentdead
No clue. Thousands running bilsteins with positive reviews.
Your front fenders are at 38.5", so your height is typical of a 2.1" truck. And that height dictates your CV angle. Lots of us are running 2.8" with no issues, so steeper angles than you. With stock tires I was over 39".
If it were my truck, I'd be looking at the CV axles and hub bearings. Sounds like something is worn and in need of replacement. How many miles on the truck?
Slip in some new axles and quit runnin around in 4WD on pavement, or,,, just quit running around in 4wd on the pavement.
Pretty sure even a new truck will 'bind' when turning in 4WD on pavement, so unclear if that aspect of your test is conclusive.
Also pretty sure the manufacturer doesn't recommend 'high' speed in 4WD on pavement either, but hey, it's your truck.
Saw the vid, looks like you found what's causing the problem.
4wd on dry pavement and getting up to 45mph isn't any test I'm willing to do.
Hell, I put mine in 4WD in November and rarely take it out until April... no issues. dry/wet/icy/slushy/dirty/snowy - highway/city/back roads driving
I am unable to view you video (work), however back when the 4th gens first came out we had a problem when using leveling kits where the front drive shaft would shake under acceleration in 4 wheel drive.
My 09 was the first my dealer had seen with the problem so they worked it under warranty. What they discovered was the change in drive shaft angle was enough to throw the balance of the drive shaft off.
So if all else fails mark the original position of your drive shaft remove and reinstall 180 degrees opposite the original position, test drive. It is a easy enough test to preform and it fixed my truck.
I had installed a daystar 2.5" front leveling kit.
Can't guarantee this is your problem, but it has happened before.
Good luck.
