All Repair Parts @ Employee Cost!
MD
Hi, I'm looking for a new upper trim cover tray for 2017 ram 1500 part # 1wq38trmaas-l400.jpg
Also interested in
thanks for your time
AllMoparParts.com
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
MD
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Is the top link for the tray? What's in the pic is exactly what I'm looking for. The link says mat and that's making me think that I'd just receive the rubber mat that goes on top of it.
My apologies no, It was the insert that sits in there. That piece appears to be part of the entire radio/hvac bezel. Can you send me your VIN and I will research this further
Thanks,
Benny
dingram77
im needing a variable valve timing sprocket its the cam phaser for 2014 ram 5.7 thanks
danielmid
Southeast WI
2015 Sport 4x4
Hey Benny, looking for a quote for the transfer case skid plate kit, part number 82214497. Seems to be out of stock most places.
BigDave79
Knoxville
Hey Benny,
Looking for this part# 68048906AA - can you help? Thanks!
JJP71584
Pgh, PA
Hi Benny, I'm looking for a satellite radio /navigation antenna for a 2012 ram 1500. Puck style that sits on the back portion of the roof. Shipping to 15136, thanks!
Sent from my SM-N950U using Tapatalk
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Hi,
From what I see the roof antenna is for sat radio only, The Nav antenna is on the inside of the truck.
Here is the exterior mounted one https://parts.allmoparparts.com/oem-parts/mopar-satellite-antenna-5064908aa
Please let me know if you have any other questions.
Thanks,
-Benny
MaxSteel2013
Hey Benny - I'm looking to finish my Rebel front end conversion and was wondering if you can hook me up with a deal on these last two remaining parts:
68251640AB and 682515041AB
Also, the exterior mounted antenna in the previous post response - can that replace the sharkfin? I'm about an inch away from being able to pull into the garage and I think that would fix it...
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Hi,
Are you looking for the left and right of the same shield? Your second number looks off.
I would need your VIN to see what configuration you have for the antenna.
-Benny
HTXRamExp
Houston, TX
Good morning Benny,
I’m looking for the driver and passenger side vertical fog light mounting brackets.
I have a 2019 classic and they modified the mounting bracket slightly, which doesn’t allow easy adaptation of aftermarket fog lights.
Here’s the VIN of a 2018 truck with OEM vertical fog lights. 1C6RR6FT3JS127372
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Good morning Benny,
Hi,
I believe the bracket may be part of the fog lamp assembly shown below
From what I can tell these bolt directly onto the absorber shown below
Let me know if my assessment is correct
Thanks!
- Benny
TMFMK
