All Repair Parts @ Employee Cost!
CraneFL
Looking for a cowl pn#55112305AD
for my 2015 Ram 1500 Bighorn.
AllMoparParts.com
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Benny,
I'm looking for rear sway bar bushings and retainers to match part number 68139812AB …
I don't have a VIN because I am trying to swap the larger 2500 sway bar onto my 1500 truck.... :)
I THINK it should be 52090271AB and 68139762AB but want to make sure they are compatible (for the 30mm diameter sway bar?)
Hi,
Using this VIN to filter parts here is what I come up with
https://parts.allmoparparts.com/oem-parts/mopar-rear-suspension-stabilizer-bar-68139811aa
https://parts.allmoparparts.com/oem-parts/mopar-stabilizer-bar-bushing-retainer-52090271ab
https://parts.allmoparparts.com/oem-parts/mopar-stabilizer-bar-bushing-68160338aa
This truck has sales code SDB heavy duty suspension but not air leveling.
Please let me know if you have any questions.
Thanks,
-Benny
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
ripping r
Old&Grumpy
earth
6.4 HEMI
CraneFL
Looking for both right and left windshield trim pieces for my 2015 Ram 1500 Big Horn. Am I doing something wrong searching, because the right side trim piece that I found was $60.00 more than the left side?
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
jordanlbrt
US
2013 2500 mega cab
Hello Benny
Was wondering about a clock switch for a 2013 ram 2500 6.7.
My heated steering wheel doesn’t work and the dealership told me I had a bad wire connection on the clock spring. They wanted more than I could afford at the time and never fixed it. Just stumbled on this thread and figured I’d see what you had available.
Thanks for any help and your time.
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Hello Benny
Hi,
Were gonna need a few weeks to get one as they are on backorder. If you would like to preorder one you can here https://parts.allmoparparts.com/oem...column-control-module-clock-spring-68110740ae I will send a code you can use.
- Benny
HTXRamExp
Houston, TX
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Hey Benny,
Is that p/n for heated wheel clock spring applicable to my 2019 express Classic as well?
Ben
Yes it is
Thanks,
-Benny
David Ross
London, Ontario
I am trying to find the Tow hooks for my 2021 Warlock but just keep finding the open hook style. local dealer told me they are discontinued is this true or is there a place to get them?
HTXRamExp
Houston, TX
Hey Benny,
I'm looking for the HSM (heated seat module) for the following vin: 1C6RR7NT3JS111163
Can you also confirm if this truck has the 8.4 UAQ or UAS radio?
Thanks!
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
They are still available, Here is a link to them https://parts.allmoparparts.com/oem-parts/mopar-tow-hook-68248844aa
You will also need the bolts https://parts.allmoparparts.com/oem-parts/mopar-hex-flange-head-screw-6104454aa
Order x2 of each . Please let me know if you have any questions.
Thanks,
-Benny
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
fingus42
