All Repair Parts @ Employee Cost!
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Benny,
Are these floor mats already on sale or do you have lower employee pricing?
Part Number: 82215584AB
retired
montana
Benny any chance of the part numbers for the plastic blind rivets that are used on the front RAM mudflaps for a 2020 Power Wagon.
AllMoparParts.com
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
The part numbers for the hardware used in the accessory splash guard kit in the link are not shown however if you can pickup an assortment kit relatively cheap online
http://starparts.chrysler.com/info/default/K6862972.pdf
It looks like the bottom rivet is metal while the uppers are plastic.
-Benny
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Benny, thank you for getting back tome so quick. VIN is 1C6RR7NT0JS182496.
No problem, The shield is part # 5NN96DX9AA
Please let me know if you have any other questions.
Thanks,
-Benny
retired
montana
-Benny
do you have the part number of the assortment kit? thanks. the generic plastic rivets that I have found are just a little undersized compared to what was in the kit.
retired
montana
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
I ordered that but those and the rivets are slightly too small. The Mopar ones are just a bit bigger.
Hmm, the most common mopar plastic rivet used is a 6500911 which is 6.35mm (1/4") diameter so I would have figured the 6.6mm in this kit would suffice. If you can measure the hole or one of the original rivets amazon sells all sorts of sizes.
-Benny
retired
montana
-Benny
funny thing is I installed all the rivets no problem and the last one did not tighten enough so I had to snip it out. the holes are drilled with a 1/4" drill bit per instructions. the ones that come with the mudflaps fit the 1/4 hole very snug. the biggest ones in that kit the ears do not expand enough to keep from pulling thru the hole. Hard to explain but seems like the mopar ones are a bit different.
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Ive worked with them before and know what you mean, The expandable portion may not be long enough so when its riveted it's not as wide. If you want to grab a few of the mopar ones from your local dealer the part # is 6500911 , The list price is 7.95 each!
- Benny
Austen
Missouri
Benny, I've looked before and had trouble finding OEM vinyl flooring for a 2016 Ram 2500. Would you be able to source the part number for me? Thanks in advance!
16' CCSB 4X4 G56 2500 6.7 SLT, CTT tuning, UAQ, Customtronix Enzo, Single Zone ATC
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Sure but I need to know if you have the Rear Air Suspension option?
-Benny
Austen
Missouri
HappilyUnstable
Minnesota
6.7L
Benny,
I need to pull my hvac as my evaporator has clogged up due to lack of air filter. Thought I should replace the evaporator/heater core and the recirc actuator and door while I'm in there (they are broke). Can you give me a quote on those 4? 2015 RAM 2500 CTD crew.
Thanks!
Alex
AllMoparParts.com
AllMoparParts.com
- Benny
All
All
Benny,
Thanks!
Alex
Hi Alex,
Sure but please PM me your VIN and Email address and I will send you a quote.
- Benny
Agcat
