Alpha obd problems
R
Rob3069usmc
NY
Might want to double check the connectors, unplug them and look for a bent pin maybe? Were any changes to the wiring needed for the aftermarket lights, jumpers, resistors, etc, anything like that?
I will look at them... no changes to the wiring or jumpers. I think I just really screwed up with alphaobd. Lesson learned to back it up before I start.
jawzs2
South Jersey
What are you running AlphaOBD on? Sometimes it will save a "BODY_CHRYSLER_Info.log" somewhere in the file structure that will show what was changed. For example, here's what was entered in mine when I installed the SmartBeam rearview mirror
Car configuration change: Auto Highbeam: ' NO ' -> '1 '
Car configuration change: Auto High Beam Module Location: ' NONE ' -> '1 '
Car configuration change: Smart Beam Present (AHBM): ' NO ' -> '1 '
Car configuration change: Auto High Beam: ' NOT ENABLED ' -> '1 '
Car configuration change: Auto High Beam CSM Present: ' NO ' -> '1 '
R
Rob3069usmc
NY
For some reason it won't let me attach the file
R
Rob3069usmc
NY
What should this be on? It's selected as none right now.
mtnrider
Georgia
Ok.. yeah I'm going through it now thanks
Let me know if you find anything. I really think those faults are the reason you are having issues. Whether that is a wiring issue or maybe a damaged BCM I can't tell? Several of those lines are shorted or open
R
Rob3069usmc
NY
Well one of the warning lights says left low beam is out and it comes on with the lights.
