Alpha OBD Question
mikegrook
Medford , NJ
2020 Power Wagon
If anyone has the name of the module to connect to. I have Alpha OBD from when I had my 2015 1500 Big Horn. Used it extensively and have all the working codes/ fixes stored in my One Drive. I also purchased and hooked up the bypass harness and still have the Bluetooth OBD link. I want to change my tire size as well as change the fog Lites off with high beams. I cannot find the name of the module to choose to connect to for a 2500, Unsure how specific to be, but just in case its a 2020 Power Wagon. Thanks for any input
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Are you talking about the BCM (Body Control Module)?
M
mikegrook
Medford , NJ
2020 Power Wagon
Yes, but the full name to choose within the Alph drop down menu. And wow! that was a fast response (example: Body Computer my13-17)
I am unsure what to choose for the 2500
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
Haha, I just set down and hit the new posts button and yours was the first to pop up. In the select control unit drop down, it will list body computer and under that you'll select MY2015 PowerNet.
*It's AlfaOBD by the way (may help when you search the forum)
M
mikegrook
Medford , NJ
2020 Power Wagon
Thanks for your help. I will try tomorrow if time permits, If not one more item to add to Saturdays list of To do. I will follow up and hopefully wont brick my truck. I am aware when changing tire size you also need to reset the anti-lock system.
GeauxinUp
Navy Badge
Louisiana
2026 Limited
3.0L TT H.O.
No prob...check out THIS thread
