Alphaobd
WaRam2012
Washington
I just bought a 2012 Ram Laramie
And was wondering if the Alphaobd can change much on the older Rams like the OEM brake controller's if added
WaRam2012
WaRam2012
Washington
Okay I will do that just looking to see if it was worth while buying the Alphaobd for the older Rams thanks again
Dinky
Oregon
Depends on how much you plan on messing with your truck. i know most dealers will charge $150 to flash and turn on the brake controller so right there you will save money on buying Alfaobd and a obd scanner.
AkNoad2
AlfaOBD isn't available for iPhone users yet is it?
Highway
Ky
Just purchased alfaobd and windows and android are the options. I chose windows and use with bluetooth laptop
KeepRight
ExFalconFxr
US
EcoDiesel
any recommendations on where to buy from
Are you sure you need to be messing around with your truck's brain?
If you are asking about using the OBD and Alfaobd, yet do not know where to buy these or that Alfa doesn't work with Apple phones. That includes one post (@chopperman1) here suggesting that you do a bit more research.
I do not mean to insult you or anything...Yet, you can do more harm by messing with the brain.
If you need or want a trailer brake controller, research what are the best ones - either OEM or aftermarket. Then let the installer worry about programming your truck.
