Amp problem...need help!
THEBAD1
2003 Sport SLT QC2WD
Hey guys, need some input!
I have a Rockford 501S amp, it has worked fine for over 5 years. Today (at a show) the sub was cutting out? Well, the amp powers up and after a few minutes cuts off, and is VERY! HOT! ....is the amp fried?
Thanks for any input!
05singlecabHEMI
Lilburn,GA
if its gettting hot doesnt that usually mean there is a bad connection somewhere?
ramhunter9
P-Star Jeep Wrangler
My amp draws allot if I dont turn the truck on ... subs cut off if the truck is not running .
Did you notice this when the truck was not on ?
THEBAD1
THEBAD1
I have ran the amp for years with the truck off ( and yes, it was off )....it has never cut off and I run 3 of them.
ramhunter9
Sounds like you need to check your grounds
blackout11
alpharetts GA
2011 R/T
usually if it gets real hot its going bad not getting the air it needs same thing happened to me i swapped it out with another using same wires and it worked fine
BigMike005
Miami, FL
i have and old school us amp, it would do that when the voltage to it was getting low...maybe since you had the truck off it was draining you battery...
THEBAD1
THEBAD1
Well, it's FRIED! Hooked it back up today and after an short time it cut off...and I could have cooked a egg on it.
Mega Mike
Long Island, NY
I had a Durango that the amp would cut out when it wasn't running. I was drawing too much power from the battery. Also, had a relay switch installed. The amp was drawing too much power, and I believe the stereo had a "safety switch" in it.
But after reading the last thread, sounds like you fried it up. I would recommend Memphis Audio. I had mine for 6 years and still going strong.
zack
pa
2004.5 packing the smarty
5.9 cummins ho
I have a mtx amp an it shuts down when it gets hot kicks back on when it cools down only does it when really rocking out for like 20 30 mins straight has done it since new
Mega Mike
Long Island, NY
My Memphis Power Reference, stays on all the time. I have had it running at least 4-5 hours straight, no issues. Yeah it gets warm/hot, but never shuts off.
